Question about Cisco Linksys CM100 Cable Modem Modems
Modem setup - Cisco Linksys CM100 Cable Modem Modems
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
Connect router to modem
Connect the modem to the Internet port and computer to port 1 on the router.
Open the setup page of the router and change the settings manually.
See How to setup Linksys router
Watch video: How to connect router to modem.
Feb 07, 2012 | Linksys Wireless-G WRT54G Router
The internet button is on, but I don't get internet from the router, only directly from the modem.
This an wire setup gone wrong!
The wire you use to get the internet from on your modem, plugs into I believe a Yellow port at the back of your router.
The rest of the ports are for hardwiring each computer.
So your computer, We say #1, will have a wire from you LAN card at the back of you computer to port #1 on you router.
you will have to go into your windows internet setup to change some settings. So to do this
My computer, Control Panel, Internet setup.Internet wizard setup.
You no longer SAY you use modem for internet, but setup through router.
This will NOT be a new setup but an existing setup
Aug 05, 2010 | Linksys Computers & Internet
How do you get connection in a sb4200 motorola
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless. OR
u can get connect by IP adress has well
go to explorer after contecting the cable in lan port to modem
type your IP adress which come from company by difold
(http://192.168.1.1)
after that your open your modem setup from there you can setup according to your locale sevice provider setup
Apr 18, 2010 | Arris SURFboard SB4200 Modem
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
Can't setup the modem to get online automaticly
Is this for windstream ISP? If so you need disk for modem or go to http:\\192.168.254.254 for setup.
May 31, 2009 | Alcatel Speed Touch Home Modem
I need the driver disc for a Linksys BEFCMU10 version 4 and a disc for a Linksys WRT54G version 2.
you don't have to use a CD to setup these routers. you can set them up by accessing the router setup page.
for other questions on how to setup the BEFCMU10 modem and the WRT54G router, you can go to www.linksys.com/kb
Feb 25, 2009 | Linksys Befcmu10 Cable Modem W/usb & E-net...
Setup Wireless Router to Westell 6100 modem
Your Wireless router should have come with a CD. Insert the CD into your computer and follow it step by step. If it did not come with it here is a basic wiring setup.
From wall jack to Westell modem, From modem to uplink port on Max G router.
Reboot Westell modem. T
Everything should auto-configure unless you need a username and password for your DLS. If so you will need to program this into your router.
Dec 21, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Wireless router 300M no acces to the internet
You need first to configure the router to work with your modem, if you have the setup CD of the router just that one and then follow all the steps on the setup CD after you're done running the setup CD of the router power down modem and router for 1 minute then plug the modem first wait for about 30 seconds and then plug the router back , after that check if internet is already working........
Nov 07, 2008 | Sitecom xDSL/Cable Broadband Router DC-200
Cisco Linksys CM100 Cable Modem Modems Logo
27 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
