Question about LG 42LW4500 3D LED Television SWV3432S/10 HDMi Cab- 24 Carat goplated
LG42LW450U wIll not switch on
When I push the power button, the light is red. The red light will then get brighter, pulse once, then dim, then get brighter once more. The light then turns white as normal but will then switch off. I've had the PSU out to have a look at the capacitors but cannot find any that have burst or leaking. I can hear the relay clicking on and off as it normally would. I've given the PSU a clean in the hope that this might be the cause but no cigar. Can anyone give any advice on what might be the cause before I go and buy a new PSU. Oh yeah, the TV is 18 months old
  • Clive Betts
    Clive Betts Nov 21, 2013
    I tried a new PSU but the problem persists which indicates it is coming from the mainboard. Now, It has been quite difficult to source the mainboard for the 42LW450U, in fact, I've not yet been able to buy one. However, I've noticed that the mainboard layout of the 32LW450 is exactly the same - minus the side metal bracket. Every chip is in the same place, to anyone they would think it is the same board. What I need to know before splashing out on one is whether or not this one will work.
    Top Expert:
  • LG Master
  • 34,704 Answers
The problem could be something other than a dirty PSU, such as failed components that can't be detected by visual inspection.
Posted on Nov 17, 2013
The headlights pulse while the engine is running
Pulse? you mean the elevation mechanism is oscillating? or the lights go dim and then bright like you were constantly on the dimming switch? if this, there is a dimming switch/relay that operates from a single pulse from your driver's dimming switch. I am guessing you have a cross over from power supply and engine vibration does the pulse. Follow the headlight wire back from to a little box, probably metal. Check all connections and possible crossover. It could be within the switch and going haywire. You may be able to listen to the continuous clicking. You may be able to rebuild it, but may not be worth it. So buy a new one. If it's the elevation mechanism, there may be a similar relay for the motor but connected to the lights on switch. There may be a faulty relay, or again viabrating donnection with a make break operation.
Mar 15, 2015 | 1976 Chevrolet Corvette
Back light dim when start up then get brighter
Normal.
When the ignition is first turned on (but before the engine is started), the light is running just off the battery, which may not be fully charged.
When you engage the starter, this is the biggest power draw there is from the battery, causing the light to dim even more.
Once engine is running (if everything is working right), the alternator powers the light, as well as everything else.
In fact, if may/may not get brighter as you rev the engine.
Feb 17, 2014 | 2010 Piaggio Typhoon 50
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Electrical
im reading along dying to hear more ,sounds like melted wires ???
shorted power lead ???ground ??? .
do you really think you burnt control mod.????
Sep 23, 2012 | Chevrolet Silverado 1500 Cars & Trucks
Need a new switch
try this place http://www.shopjimmy.com/ they are the best
Sep 04, 2012 | Apex Digital GT2015 20" TV
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Hampton bay model uc 7083t light very dim when turned on
You probably have one or the other of the remotes pictured below:
In both cases, if you press and HOLD the button labeled "Light / Dimmer" (top remote) or the top round button with the light bulb icon on it (bottom remote), the intensity of the lamp will become brighter until it is at maximum and then become dimmer until it almost turns off . If you continue to hold the button, it will begin to get brighter once again. Pressing the button quickly simply turns it off when it is on, and on when it is off.
The buttons on the remote leave a bit to be desired as far as how well they work. You should keep an eye on the red LED indicator while pressing any button. If it fails to light the command is never sent. If it stops lighting while holding a button in, (to send a dimming or brighten command to the lamp) the command stops being sent and the intensity of the lamp no longer changes. I have found that sometimes I have to press the edge of the button to get them to work. If yours is giving you trouble - you might try that, too.
I hope this helps & good luck!
Sep 09, 2011 | Hampton Bay 24002 Ceiling Fan
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
Light on freezer door stays on dim until door open
Did you try pushing the light button several times. It might be the dimmer type
Jul 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
LG 42LW4500 3D LED Television SWV3432S/10 HDMi Cab- 24 Carat goplated Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
