Panasonic pv 4561
No power to unit. Checked the fuse on Power supply with multi-meter it is OK
    Problem Solver:
  • 18 Answers
Please check the power supply of your TV,multimeter the export voltage of power supply.if it is defective you can replace it.
if not you need check main boards,and inverter boards
From Wisiny.com can find those parts,power supply,inverter boards and t-con
Posted on Dec 09, 2013
2 Suggested Answers
  • 1003 Answers
SOURCE: Panasonic PV-M2738 flashing light
A BAD PCB (power control board) maybe cheaper to buy new combo
Posted on Jan 17, 2008
Windshield wipers don't work on 91 taurus, fuse is ok
Maybe worth checking wiper switch or wiper motor.If you have a multi-meter it maybe worth checking power supply to switch and motor..hope it helps.....
Dec 30, 2012 | 1991 Ford Taurus
Panasonic PV-4664 VR wont't power on. Replaced 1.6A input fuse and fuse blows immendiately when power supply is both installed and removed from the unit. Appears the power supply has a problem.
Fuses blow like that when a semi-conductor has shorted and acting like a piece of wire. Transistors diodes etc will show up quick with a Ohm meter, has it will be just like you have touched the probes together!
May 08, 2011 | Panasonic PV-4664 VHS VCR
My panasonic ae900 projector suddenly stopped getting power. No indication lamp is lit.I checked all the outlets and power cords.Could it be a fuse? if yes, where is it located?
there is 2 fuses, one in the power lead and one inside in the projector close to where the power cord enters the rear of the unit, the one inside is white in colour, remove the fuse and test it with a long nose plyers and test it with a multi meter, then you know if you need a new power supply or software
Aug 22, 2009 | Panasonic PT-AE900U Multimedia Projector
Panasonic dmr es30v
Without seeing the actual unit, I would guess that the power supply has failed. These unit have what are called "switch mode" supplies that rely on circuits that oscillate. If a capacitor goes bad, the unit won't oscillate properly, thus no power. These are difficult to track, but are not usually expensive to repair. I would suggest a trip to a service center for a detailed repair estimate. Report the results here.
Dan
Jan 31, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
Apr 11, 2008 | Panasonic PV-V4021 S-VHS VCR
** power
There is usually a fuse on the back of the unit. Did you check that? There may be a power supply issue to where ever you took power from? Maybe not a constant or "breaked" tap point. Go over the following site and see if it helps. If all else fails, the unit could be faulty. Go back for warranty.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 09, 2008 | Panasonic CQ-DFX302U CD Player
Unit is dead....
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Panasonic WV-CM1020 Television
Panasonic DVD/VCR combo Player,PV-D4734S
Read a post from tech-net.archive.net for the values:
d1o41 20vz diode - shorted
pr1005 1.5A ic protector - open
Please post if your repair worked!
Oct 26, 2007 | Televison & Video
No power
open unit. look for a board-mounted fuse in power supply section
Jun 03, 2007 | Panasonic PV-V4612 VHS VCR
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
