Question about HP DesignJet 750c plus InkJet Printer
Leave in cartridges ?
When not in use should I leave in or remove ink cartridges
    Problem Solver:
  • 7 Answers
You don`t need to remove cartridges, just don`t forget to print something at least once a month, to prevent nozzles dry up.
Posted on Nov 19, 2013
Do I have to replace the color ink cartrigdes in my epson xp-610 printer
Q:
How do I change the ink cartridges?
A:
Do the following:
Removing and Installing Ink Cartridges
Make sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
  1. Make sure that the CD/DVD tray is not inserted for printing.
  2. Turn on your product.
    • If an ink cartridge is expended, you see a message on the LCD screen. Note which cartridges need to be replaced and press OK . Then select Yes, replace now and press OK .
    • If you are replacing a cartridge before you see a message on the LCD screen, press the left or right arrow buttons, select Setup > OK > Maintenance > OK > Ink Cartridge Replacement > OK . Then press the start_black_icon.jpg start button.
  3. Lift up the scanner unit.
    Caution:
    Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
  4. Push in the blue tab to unlock the ink cartridge you are replacing. Then lift the bottom of the ink cartridge to remove it.
    Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
  5. Recap the used ink cartridge using the cap that came with it.
    Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
  6. If you are replacing the Black (BK) ink cartridge, it is recommended that you shake the new cartridge gently four or five times before unwrapping it. You do not need to shake the Photo Black (PBK) cartridge or any of the other color ink cartridges.
    Caution:
    Do not shake the cartridges after opening the packages, or ink may leak.
  7. Remove the cartridge from the package.
    Caution:
    Do not touch the areas shown above. Doing so may prevent normal operation and printing.
  8. Remove the cap from the cartridge and store it in the bag that came with your product for later use.
    Note: Save the cap so you can recap ink cartridges before storing or disposing of them.
    Caution:
    Do not remove any other labels or seals, or ink will leak.
  9. Insert the ink cartridge head first into the ink cartridge holder. Then press the bottom of the ink cartridge down until it clicks into place.
  10. Once you replace all the cartridges that need replacing, close the scanner unit.
    The product starts priming the ink. This takes a few minutes. When you see a completion message on the LCD screen, ink replacement is complete. Note: If you see an error screen telling you an ink cartridge is installed incorrectly, lift up the scanner unit and press the ink cartridge down until it clicks into place. When you\'re finished, close the scanner unit.
If you remove a low or expended ink cartridge, you cannot re-install and use the cartridge.
Caution:
If you remove an ink cartridge for later use, recap the ink cartridge using the cap that came with it to prevent the ink from drying out and to protect the surrounding area from getting smeared by ink. Store the ink cartridge in the same environment as the product. Do not leave the product with the ink cartridges removed for an extended period of time. Otherwise, ink remaining in the print head nozzles may dry out and you may not be able to print.
http://youtu.be/xJsDu52txEA
Nov 17, 2014 | Epson Expression Premium XP-610...
Printer can not print Error Number 5200
To solve your problem follow the instruction step by step. Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display . Thanks
Aug 22, 2011 | Canon PIXMA MP495 InkJet Printer
Hi, my canon MP250 is displaying the error P08 and error 5200 on the computer. Can you help me please
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
Jul 21, 2011 | Office Equipment & Supplies
Alarm light is on and it gives an error code 5200 when i try to print from my cannon MP 495
Error 5200:
Jul 20, 2011 | Canon PIXMA MP495 InkJet Printer
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My pritnter says error 5200 i have switched offand on with no avail please help
May 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Gives me error 5200
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 24, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
The canon mp 130 printer says error 5200 and will not print.
3. Plug electrical cord back in, when ink cartride carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
Thanks, Joe
Feb 10, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Says to replace cartridge which i did but it still wont print.
Why isn't any ink coming out of a new ink cartridge that has just been installed?
The ink cartridge may have a plastic tag covering the print head, which should be removed before the cartridge is installed. If the tag has been removed and the problem persists, there may be air bubbles blocking the print head. In this case, you can try using the print head cleaning function of your printer or leave the ink cartridge in your printer for about an hour to allow the air bubbles to rise to the top of the ink cartridge.
What should be done if the ink cartridge doesn't print or some of the colors don't print?
The nozzle may be clogged with dried ink. The print head should be blotted with a damp lint-free cloth to remove the dried ink. If this does not work, try soaking the ink cartridge in water for a few minutes. To soak the ink cartridge, place it in a Styrofoam cup and fill the cup with water until the ink cartridge is halfway immersed in water. If the ink cartridge does not print after this is done, try soaking the ink cartridge overnight.
Hope it helped...
Oct 28, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Replaced cartriges with remanafacuter. Front
Try removing all 4 ink cartridges and unplug the power.
Close the ink cover, leave the ink cartridges out and then plug the power back in.
Once the printer boots up completely, reinstall the cartridges
Mar 26, 2010 | Dell 968w Printer
HP DesignJet 750c plus InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
