Question about Refrigerators
Kenmore upright freezer model 970-217422 serial # wb22423089
Bgillespie
  • 89 Answers
SOURCE: GE Upright Freezer is not freezing
It is very common for the "relays" to go out on the compressor. The relays are mounted on the left side of the compressor. You need to find an "Appliance Parts Store" and buy an "RO-41". (this is a relay) it cost no more than 10 bucks. Go home with your new bought relay and pull your refrigerator out from the wall. Don't forget to unplug it! Take off the rectangle card board cover off the bottom of the refrigerator "in back"... More than likely 1/4 nut driver. Now look for the compressor--"The Roundish black thing the size of a basketball". Next, you will see a box looking thing (black, white) mounted on the side of the compressor with 2 wires going to it. Next take it off the side of the compressor. It just pulls straight off! Sometime though it may be held in place by a little clip. Now read the instructions with the RO-41(inside cover). You will end up cutting the old relays off. Take the two wires that went to it and wire them into the relay(follow the instructions w/relay) then other wires on relay plug right into the compressor! AND THATS IT! It sounds hard but aint... goodluck!!!
Posted on Dec 17, 2007
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
abhishek33
  • 1239 Answers
SOURCE: Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Posted on Nov 06, 2008
  • 9 Answers
SOURCE: kenmore model 970-224221 upright freezer
The compressor will make a loud "thump" sound if the motor inside has broken loose.
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Posted on Feb 17, 2009
My freezer has power but is not cooling is there a reset
no, need more info, model serial and do you hear anything at all.
Jan 27, 2016 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Where can I get a freezer door key for Kenmore upright freezer model 39153
Locksmith.....just take the model number and serial number to them. If they can't, most likely have to be from the manufacture.
Oct 07, 2015 | Kenmore Freezers
Freezer age and kwh usage for kenmore 2722
go here,put the name,model and serial numbers in and it will tell you how old any appliance is.
http://www.appliance411.com/service/date-code.php
Jul 10, 2013 | Kenmore Freezers
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
ThanksTalkAppliance.co.uk
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
My Kenmore upright freezer, serial #WB95125779, model #253.9284213, is not freezing my food? All of my frozen food was spoiled. Can anybody give me any solutions?
You may need freon, or your compressor has died. Either way you need a service guy. Sears has their own service people. It may be under warranty.
Apr 22, 2012 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
