After the cycle finsihed, it got caught in endless cycle of filling and draining.
This is brand new product. Completed the wash cycle, then the LEDs went out, and the machine continuously filled and drained.
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 224 Answers
If brand new, seek warranty help. sounds like it has gone into flood mode
Posted on Nov 18, 2013
  • 1294 Answers
SOURCE: Washing machine fills with water when not in use.
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Posted on Feb 11, 2008
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
docjohn174
  • 943 Answers
SOURCE: Model# 110 20902990 kenmore washing machine over flows
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Posted on Sep 27, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
My indesit wixl143s, fills with water normally but immediately it drains. washing movements do not start. When manually set to rinse and spin cycles it works.
I would like to know is there any fault code?
Identification of the error code using the 4 LEDs. One or more different combinations of LEDs indicates the failure.
25889772-23mqg50qavgoaobxweiobkxp-5-0.jpg Dado
Oct 02, 2015 | Indesit Washing Machines
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Fills up with water, wont wash, drum motors works
Sounds as if this computer is trying to display an error code. If switching cycles manually makes it work, then it is most likely a bad circuit board. Try doing a google search for "Kenmore washer lights blinking" or something to that effect.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machine
the problem is the pumping out of the water it be something caught in the pump or the pump is faulty remove it check it out. Close Ireland,bye bye
Nov 21, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
