Question about Mr. Coffee Coffee Makers & Espresso Machines
Beep like its done
My coffee maker beeps like it's done way before it's really done. it still brews but takes much longer than it should. is this something that can be fixed or do i need to buy a new one?
    Problem Solver:
  • 8 Answers
It sounds like the coffee exit needle is blocked. Take a small paperclip and carefully insert upward into exit needle, swirl to dislodge debri. Do this for all three of the holes in the exit needle.
Run "Brew" without a KCup to see if this clears the exit needle.
Posted on Nov 17, 2013
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
SOURCE: Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
Posted on Dec 21, 2009
  • 1739 Answers
SOURCE: this coffee maker (10 c maker with grinder) beeps
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Posted on Jan 30, 2011
austinrobb
  • 7 Answers
SOURCE: KitchenAid Coffee maker KCM111 brand
Sounds like it is broken. Should be under the manufacturer's warranty. Go to the store and get it exchanged. Or contact KitchenAid.
Posted on Sep 13, 2011
mc1bean
  • 3053 Answers
SOURCE: I've had a 12 cup
Hello, a
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
Apr 07, 2011 | Coffee Makers & Espresso Machines
Clean light stays on,help me trouble shoot
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I have lost by cleaning manual for my dcc-1200 coffee maker. I need to clean it the light won't shut off. Thanks, Dawn Miller
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Turn off beeping alarm when the coffee maker is done brewing
Mar 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Kenmore Coffeemaker 100.82006
Good news. Sears has a recall on these coffee makers. You can take it to any Sears store without a receipt and they will give you your money back on a gift card. They were determine to be defective.
Feb 13, 2008 | Coffee Makers & Espresso Machines
Turning off the beeper
The manual is not too clear on this function. Turn the coffee side on, press the middle button on the coffee side for > 2 seconds and then use S1 and S2 button to select a mode that does not show the bell.
Jul 11, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
351 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
