Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
Whirlpool gold dishwasher gu1200 sani rinse light blinking
3 Suggested Answers
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
rickead1
  • 1998 Answers
SOURCE: KitchenAid Dishwasher KUDS01IJ will not
couple things you can try first hold down cancel for ten seconds this usually cancels the cycle and puts the unit in the drain function or you can try hit high scrub and than energy saver and repeated the same after a few seconds or if this also doesnt work then you could also try shutting of the power by way of the breaker for 5 minutes which usually causes the controler to reset if none of these tests work message me back and we can perform other tests also how many times are the lights blinking if its 3 times then these tests should correct the problem if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Posted on Feb 05, 2011
I have a whirlpool dishwasher the normal and sani rinse and cancel lights are blinking. i cannont cancell the cycle and will not run The model # GU1100XTLT1
Shut breaker at circuit breaker panel that feeds the dishwasher for 5 minutes then turn on again and verify dishwasher has cancelled wash itself.
Jun 14, 2016 | Whirlpool Dishwashers
My washer wont start, I can't get it to cancel or reset. I unplugged for 10 minutes and all lights are still on.
We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 14, 2017 | Whirlpool Gold GU2275XTV Builtin...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean ligh is blinking
youll need to remove the bottom acess panel of d/w there should be an extensive trouble shooting guide tapedto back of panel in a sleeve, lotsa good stuff in there. depending on buttons its going to repuire pushing a sequence. "
sani-rinse---heated dry--sani rinse--heated dry.
it will enter a diag mode "all lights will light up" wait a few secs and then cancel cycle .. if happens a again or with frequency, then call a servicer, you have a problem, first time chaulk up to a fluke
Mar 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Mar 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
60 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
