Question about Mastercool 67471 Evaporative Cooler Air Conditioner
How to drain a mastercool evaporative system ADA71
EVERY HOUR OR SO WATER IS POURING OUT OF THE DRAIN, WHY?
There is a float in the evaporative cooler that will let water in when the trough is low and then when it fills, should shut the water off. I would check to make sure that the float arm is not corroded or misaligned.
Aug 17, 2011 | Mastercool 67471 Evaporative Cooler Air...
I have a MasterCool II MC63/64B and the thermostat has gone out. Since MasterCool is out of business, what model/brand would I replace it with.
If you are just running the evaporative cooler any single stage thermostat will suffice. You can buy them at OSH, Home Depot or Lowe's and probably Ace Hardware.
Aug 03, 2011 | Mastercool 67680 Evaporative Cooler Air...
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
Drain light on
You have a blocked drain line you will need to unblock it with either forced air
May 31, 2010 | Mastercool 67471 Evaporative Cooler Air...
How do i drain a mastercool of water manualy?
Remove drain pipe from water pan. You can usually turn it counter clockwise. When drained, clean with fresh water and replace pipe buy placing pipe dope or teflon tape to avoid leaking.
May 05, 2010 | Mastercool 67471 Evaporative Cooler Air...
Evaparative cooler system
Hi; If this is a rooftop unit it will usually have a removable plug. This has two purposes,wintertime shutdown,cleaning..alpharome416
Jan 17, 2010 | Mastercool 67680 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
My Mastercool Trio System has experience a failure od the compressor fan. ACExperts, the installer and only dealer in El Paso has gone out business.
is this not a Evaporative cooler if so there is no compressor the only two motors one for the Fan and a Sump pump. and most you spend 200 for fan motor. this is swamp cooler!
Jul 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Low voltage wires
I just tested a mastercool control box and found these 4 control wire colors:
Red (24v supply)
White (pump)
Green (low blower)
Yellow (high blower)
The yellow acted as a common for testing when the blower was not on high.
Blower on low just green has 24v.
Blower on high green and yellow have 24v.
If there was a fifth wire added hopefully it would be a ground wire.
There was also the low gauge wires that were black, white, and ground that were not control wires and delivered power to the control box.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Summer
If it was not drained for winter, do so and then remove all scale from the pan, pump inlet screen, etc. Replace the pads if they are scaled up and remove any scale from the louvered panels. WITH THE POWER OFF, check the belt for cracking and check to drive motor and blower wheel bearings for smooth operation, oil bearings with oil ports. With clean water in the sump, a good drive belt, clean pump screen and clean pads, the unit is ready to power up and run test the float action/shut-off, water distribution through the arms, belt tension (just enough to prevent slipping). These units work best when they can fully evaporate the water, so let the air flow out as fast as it come into the cooled space to maximize the evaporative effect. Also note, these unit must be level to work properly.
Apr 27, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
