Question about Electrical Supplies
No watts being produced
Ive flashed this and still not working, any other other possible fixes to try before replacing entire generator part?
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
Ohm the rotor between the rings with a good meter, and also from each ring to ground metal shaft of the rotor. You should have a low resistance between the rings, and zero to ground. Also disconnect the stator wires and do the same. I doubt you have to change the whole generator. Make sure you have battery voltage on the brush wires while cranking, if you do then the control AVR is working. If you don't then its a control board issue
Posted on Nov 17, 2013
4 Suggested Answers
ccrozier_agr
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
  • 1388 Answers
SOURCE: 10,000 watt generator 220 plug doesn't work
Most generators have several circuits incorporated within the windings. There are usually two 115v windings, one or two windings that produce power and sensing voltage for the regulator that supplies power to the armature (produces magnetic force) and sometimes a 12v winding to supply power to charge the battery. The two 115v windings power one 115v plug each and together power the 220v plug. Each outlet has a breaker and or ground fault. Since the 115v plugs are working indicates that the 220v plug must have an open/broken wire or faulty breaker. Easy to check, however you must open cover to wiring compartment and trace wires. Should be easy fix. You do not have to start engine to find broken wire. Use ohm meter instead. With engine off, Insert probes into 115v plug and obtain ohm reading. Then insert probes into second 115v plug and obtain similar reading. Look for same reading at the 220v plug (remember 2 circuits of 115v, ground and neutral). Good luck with your repair and email if you have other question.
Posted on May 10, 2009
sal_kh_sab
  • 98 Answers
SOURCE: I own a coleman powermate 1000 watt generator. the
try checking the AVR card...or wireing....
if all of them r fine...chek the brushes
Posted on Oct 11, 2009
Have a 4000 watt sportsman generator that will not produce electric i have replaced the avr what next
Could be lost exciter current. This is how to restore it - Connect 16 or 18 gauge wires to a 12 volt battery. With generator running, insert bare ends of wires into AC outlet - one to Hot, the other to Neutral. Insert and remove quickly. There should be a flash and power will be restored. If not, repeat until you get that flash and output current restored. Using light gauge wires is so that if you are too slow to remove them once AC is restored. they will burn out before the battery suffers from the AC incoming. Be quick and be careful.
Mar 31, 2014 | Buffalo Tools Sportsman Series 4000 Watt...
Onan 7000 generator runs but does not produce electric to rv
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
Oct 16, 2013 | RTO Cummins Onan HomeSite Power 5500
Need help with diagnosing generator not producing power
may be a bad breaker or a shorted wiring problem. not generating any power, I would ck. the brushes inside the generator.
May 19, 2013 | Briggs & Stratton Power Products 5,550...
Hi I have an eagle power generator (E65DRE) and it will not generate power. All the coils and components are alright. Do I have to (excite) the generator after it has been sitting for a while? Has any one...
Yes, that's exactly the issue. You should run it once a month to avoid this. Generators can't sit for a while or they will loose the charge that excites the coils for producing power
Sep 07, 2009 | Eagle 10000 W Portable Generator
My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
Jun 20, 2009 | Electrical Supplies
May 09, 2009 | Electrical Supplies
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Nov 28, 2008 | Electrical Supplies
Electrical Supplies Logo
23 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
