Question about Sceptre X46BV TV
Tv won't come on even though the power indicator light works
Blue light comes on but tv won t turn on no picture or sound nothing works
The blue light merely indicates power is getting to your TV. The internal power supply may have failed.
Aug 15, 2014 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
Tv won't turn on power indicator light not lit
As you mentioned the tv have problem with the power supply stage. Before suspecting for any intenal fault Chcek the following first. Remove the AC plug of the tv and connect the same in any other wall outlet. If then also it shows the same problem then its the powersupply board of your tv.
working on power supply board should be done by a skilled worker. Because there is risk of electric shock even if the power is disconnected. some of the capacitors will hold charge even if the power is not connected.
Here i have adde the link which will lead you the powesupply board.
Power supply board
Ajin
Apr 01, 2012 | Magnavox 32MF338B 32 in. LCD HDTV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My Tv power light is not on
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
Feb 24, 2010 | Protron PLTV3250 32 in. LCD Television
Sceptre X46BV TV Logo
49 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
