Question about Electric Stanley Tre500 Staple Gun / Sharpshooter
The staples are getting jammed - Electric Stanley Tre500 Staple Gun / Sharpshooter
Bostitch b8e
There could be a piece of a broken staple jammed in the stapling mechanism. I checked mine and there are two screws on the bottom that can be removed to expose the interior. The broken staple jam occurs often with mechanical staplers so the electrics probably have similar failures.
May 29, 2014 | Office Equipment & Supplies
Staple is jammed
Open the area where more staples are inserted, remove the staples, then find the jammed staple. You'll probably have to wrench it out with pliers. Then insert the good staples and try again.
Dec 28, 2013 | Tools & Hardware - Others
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
My etfx50 arrow staple gun jams, what can I do to fix this problem?
There is a screw and nut at the feeding end of the gun that allows you to remove the guide and get to the jam. Make sure it is unplugged and prepare for the firing mechanism to eject the jammed staple. Otherwise, a pretty simple maneuver. Wish Arrow would have included such in their owner's manual.
Nov 30, 2010 | Aerobie Arrow Etfx50 Staple Nail Gun
Bostitch nail gun number SB-21n1 is jammed and need manual to know how to unjam it or a solution online. Was using it in the staple mode and it jammed after about 5 staples. Was using bostitch staples.
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Jan 12, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
How do I open the swingline model 900xd
It took me and my boss wrestling with this mongo stapler for 15 minutes to figure it out! :0)
To open the front end, pull up on the handle while simultaneously pushing down on the small black lever on the front. This takes some firmness and be warned, if it's jammed with staples it's going to take some serious force to get it open - watch your fingers!!! I strongly suggest the minute you get a jam, open up the front and clear it. Don't continue to staple in hopes it will work or clear itself or you will have a build up of jammed staples making it almost impossible to open and clear. Also note that when you open up the front end the staples tend to shoot out so be careful.
To open the back end to load staples, push forward and up.
Hope this is of help :0)
Dec 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Arrow T-50 stapler
Take out the screw/nut combo @ the end of the gun where you load the staples. The whole rail that holds the staples will then come out and you can then get the little devils of the nested, jammed, rousted up staples out by sliding them out with a screwdriver. Don't jam the screwdriver into your fingers/hand when doing it.
Nov 03, 2008 | Arrow T25 Staple Gun
Electric Stanley Tre500  Staple Gun / Sharpshooter Logo
23 people viewed this question
Top Electric Tools & Hardware - Others Experts
eddie_brown
Level 1 Expert
Mike Carew
Jim London
Jim London
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
