Question about Logitech Premium Headset
Cut Cord My cat cut my cord and I have tried many times to re-wire the cord back together, but I still cannot get the sound to work. Anyone know how to fix it? When I am looking at the wires their is a blue, red, and gold wire that goes to the headphones. They are not seperate, and are all touching. Their is a seperate insulated cord for the mic and I can't get it to work either. I am sure its the cord because it worked before it was cut. PLS Help! Thanks
  • Logitech Master
  • 1,830 Answers
Please specify. What did the cat chew the wire to?
Posted on Jun 20, 2017
SOURCE: Logitech headphones not working with MSN
The internet bandwidth or speed is too low or being occupied by some other programs.Thereby leaving a low speed for the msn to work.The solution would be close some applications using internet or reinstall the msn messenger.
Posted on Jan 19, 2009
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
SOURCE: My headphones work, my mic does not(at all)
Have you gone to your control panel, and found the "speech recognition" option? If you havent tried it, do that. It wil have you recite a sentence and then should conifgure your mic to your computer. I hope this helps!
Posted on May 30, 2009
denverod
SOURCE: my mic is not working on my laotop,vista home premium
you do not need to uninstall any driver..i had the same problem and i just bought a new headset wid a mic so here's what probably your problem is...especially those who can't seem to uninstall their driver..
1. right click on the speaker icon and go to recording devices 2. select any of the microphones in the list 3. click on properties 4. go to the levels tab 5. unmute your microphone and voila..microphone works :)
Posted on Sep 15, 2009
SOURCE: USB Headset mM/N:A-0374A mic problem
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
Posted on Dec 29, 2009
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
How do I install the standard mini inline cord switch. I am a novice.
The cord has two wires.
Use exacto knife or utility knife with sharp blade, slice the wire down the middle for about 2 inches.
Be careful and don't cut into the copper wire.
Now the two wires are separated, like each lane of a road going around a tree.
Cut one wire completely through. Leave the other wire continuous and uncut.
Which of the two wires do you cut?
Go back to the plug and notice that plug has two prongs. One prong is narrower. This prong carries voltage to the lamp, so technically and officially that is the wire to cut.
However you can unofficially cut either wire and it will work fine.
Open mini switch and there are two halves and one screw that tightens two halves together.
Notice inside the mini switch, there are two sharp brass points.
These brass points will penetrate through the wire insulation and into the copper when you reassemble the mini-switch.
So place your continuous wire in the open mini-switch. and place your two cut wires in place where the brass points will push down, you may have to trim one of the cut wires a bit shorter.
Then put the two mini-switch halves together and squeeze them together between fingers, and then tighten the screw.
That should do it.
If project fails, Amazon offers a work-around:
http://www.amazon.com/Woods-13568-Wireless-Control-3-Outlet/dp/B001Q9EFUU
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
Apr 14, 2011 | Leviton Mini Feed Thru Cord Switch -...
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Left ear doesnt give out sound
there are two reasons for which your left ear head phone is not working:
1.If the insulation between the wires(copper leads inside the cord) fails....the two leads gets short circuited and it will stop working...OR some times the cord ll be looking good but inside one of the leads got cut then one of the headphones fails...
the solution for the above problem is dont wrap the cord...this ll lead to cut or insulation failure....
2.the speaker in the left head phone got failed...
dont forget to rate me...
good luck...
Apr 15, 2010 | Bose Around-Ear Headphones - Silver
Wiring
You may be able to take the back of the speaker can off the speaker plate on that side to rewire the headphones. You have to carefully remove the earpad and look for screws holding them together. Make note of which color wire connects to what at the solder connection. Cut your cord shorter and cut back the insulation. Test for continuity from the plug to the newly exposed wires with a volt ohm meter. You should be able to get the old piece of cord out of the grommet in the headphones to insert the working cord. Hope this helps.
Jul 04, 2009 | Bose on-ear TriPort Headphones
Power cord has been cut
Yes you can replace the entire cord, or you can splice the cord back together. Get some crimp on wire connectors get a tube of heat shrink that will fit over the cord, cut back the insulation crimp, the wires back together (match color to color). heat the shrink or tape it up. Back in business.
Jul 04, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
Can bose wires be splice?
My cat chewed my bose headphone wire in two. Can the wire be spliced back together?
Nov 09, 2008 | Bose in-ear headphones - Black with...
Logitech Premium Headset Logo
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
