Question about Maytag Neptune MAH5500B Front Load Washer
Basket wont spin
Acts like there may be a broken belt
    Problem Solver:
  • 10 Answers
Do you hear the drive motor running? Most likely not I work on these machines all day every day, and have since before Maytag introduced their first Mah 4000. I have yet to se a belt break. although if your bearings are worn out it may be possible for the belt to slip off of the pulleys. If this is the case you should have been able to tell this because it would be extremely loud during spin. If not chances are good that the door latch/lock mechanism is the culprit. I would start here. Remove the top and bottom front panels and look for the tech sheet. It will guide you through the diagnosis problem. Please be careful though and only preform procedures you are comfortable with. Follow the tech sheet to the letter. If it says unplug the washer. unplug the washer.
Posted on Nov 17, 2013
Washer wont spin
see this possibles cause:
It doesn't pump or spin
frozen pump pulley+drive pump belt broken replace
It pumps, but doesn't spin
lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn
It spins only with the lid closed
safety the machine will run with the lid door closed.
God bless you
Jun 28, 2012 | LG WM1814CW Front Load Washer
Spin cycle
Did you check the belt, the motor coupling and the bearing.
If it is not cycling instead replace the control.
Sep 06, 2008 | Maytag Neptune Washer
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
Basket will not spin
Broken belt or bad motor. Do you here motor running? if yes belt has broke if not then motor could be bad.
Jun 01, 2010 | Whirlpool LER5636P Electric Dryer
My hec washing machine is not spinning and the water wont empty
Try turning the spin basket, something may have jammed itself inside the tub. You can remove the front kick panel and remove the tub to pump hose to clean it out.
If ok, you might have other problems like a broken belt in the back.
Sep 25, 2009 | Washing Machines
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Kenmore Elite Washer top load Wont spin
Sounds to me like the belt is broken or has slipped off. Try taking the back off (6-8 screws) and you will immediately see if that is the problem.
Dec 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ge prodigy wpse4270aoww won't rinse or spin
try to clean out the water pump lines from pump to out to the drain
Feb 25, 2008 | GE Profile Prodigy WPSE4200A
Maytag Neptune MAH5500B Front Load Washer Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
