Question about Belling DB90 Electric Kitchen Range
Main ovens dont work - Belling DB90 Electric Kitchen Range
Main oven dont light there is no gas coming through
Check the main oven burner and look for a small thin bar that goes across the burner on the left or right hand side, push it down and across into its seating. its part of a sensing device for the gas flow
Nov 27, 2011 | Stoves 600SiDOm Gas Kitchen Range
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
The fans arn't working, have checked the element both visually and with a meter it's ok - any ideas? The cooker is approx 17 yers old, no identifable model on front, single oven
if the elements work but the fans dont are you talking about circotherm main oven fan or cooling fans ? there are 2 if its a double oven ,the age of your oven suggests they are gummed up with carbon after years of use and will have seized up.
hope this helps
Jul 04, 2009 | Neff B1421 Electric Single Oven
Ge oven clock and oven dont work
Hi!1 your control board is shorted need a new control clock board..Just remove the screws to the top back panel and you will see the the main board easy to fix..Just buy main clock board..Good luck..
Jan 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Dec 12, 2008 | Belling DB90 Electric Kitchen Range
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven not working
main oven not heating in my creda
Aug 11, 2008 | Ovens
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Belling DB90 Electric Kitchen Range Logo
50 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
