Question about KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator
The middle support that holds up the crisper drawers has broken
The crisper drawers slide on a middle track that sits on the frame that supports the bottom shelf. A small tab holds the drawer support in place -- twice this has broken. We are not overloading, normal use of the frig as in past years. Frid was new in 2011.
    Top Expert:
  • KitchenAid Master
  • 36,376 Answers
Check with KitchenAid regarding replacement of the part. You also can try an appliance parts supplier as the tab may be a frequent failure item.
Posted on Nov 17, 2013
peyton32034
  • 410 Answers
SOURCE: Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Posted on Jan 28, 2009
erpaalai
  • 999 Answers
SOURCE: my kitchen aid Superba 48 the meat drawer is
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KSCS25INBL01&productCategoryId=0165000&brandId=0593&modelName=COUNTER-DEPTH-REFRIGERATOR&diagramPageId=00003&componentDescription=REFRIGERATOR%20SHELF%20PARTS&documentId=W0606038&blt=06
Eric
Posted on Nov 21, 2009
  • 254 Answers
SOURCE: Kichenaid side by side - new track for veggie drawer
get ur model number on inside wall of refer on sticker, go to searspartsdirect.com enter your model number and research the part u need then u can shop around locally or repairclinic.com or sears hope this helps
Posted on Apr 19, 2010
mrfixit3667
  • 262 Answers
SOURCE: KitchenAid KSBP25FJSS01 side-by-side refrigerator
Its not a major problem... It could be any of the following. The evaperator fan is not working in witch case the temps will rise soon and quickly you can check this by opening the freezer door and push the light switch if there is one and listen for the fan.
Next look at the back wall of the freezer and look fof FROST if you have frost then you have a defrost problem in withch case it could be a heater, limiter, timer, or control board.
or your thermostat is bad and is letting the compressor run longer than normal.
This should cover the most common problems.
Posted on Sep 05, 2010
rickead1
  • 1998 Answers
SOURCE: How do you reinstall satin glide system drawer?
here is the full schematic diagram for you machine you can pick which area you want blown up so you can see the exploded view if you have any further questions on how to install the drawer please pick the part number off this schematic and message me back with your question http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSCS25INWH03/0593/0165000?searchedModel=KSCS25IN&blt= and please remember when our chat has concluded to rank this opinion Thanks again and Happy New Year
Rick
Posted on Jan 04, 2011
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
Broken crisper roller tracks on KitchenAid frdge md# KBRS22KFWHO
fixya doesnt sell products or replacement parts search on line using make and model for part or notify manufacturer for a parts distributor in your area
May 18, 2017 | Frigidaire FRS3R5EMB Side by Side...
Crisper drawer support has fallen out
The rod has to be inserted inside the front of the assembly. Take the assembly out, flip it over, and look for the small spaces on either side of the front of the assembly. Slide the rod in.
Jun 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
LG LRFD22850 Replacing support grid for bottom crispers in refrig. Need help.
It is a challenge to replace those grids.  Instead of trying to fit the support grids into the frame, bend the frame slightly to fit the grids.  You will need to remove the steel support from the frame before bending the frame.  That is what I have been able to do when I have those problems.
Oct 11, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator Logo
109 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
