Question about Car Audio & Video
How can u turn up the bass speaker because its really low
    Master:
  • 274 Answers
You can turn up the bass setting on your radio, or install an amplifier for the bass speakers.
Posted on Nov 17, 2013
My stock stereo speakers go in and out. most of the time lately the speakers are real low and your have to turn up the volume almost to max to hear them decently. and then the bass and mid isn't working....
My speakers in my 2003 Silverado started to fail at about 5 years old. I just replaced them with all new speakers. They would come and go erratically and sounded horrible.
Sep 11, 2013 | Logitech X-530 Computer Speakers
Volume is really low on my HP ProBook 4440s. how can I fix it?
Are you shure all volume controls are set on max? Bass / treble or some kind of equalizer or enhancer turned on? If it's still too low, use a Boss Porta Pro headset, buy external speakers or connect to a stereo system.
Aug 11, 2013 | HP Computers & Internet
I have a problem with my z-5500! the bass is really bad, on all the effects. my friend has the same pare of speakers han his bass is really good. what should i do???
Always make sure that your computer settings for audio are checked and set accordingly and that all the equlizers and audio programs that are installed and controlling your audio sound output are accounted for and adjusted properly.
Feb 07, 2012 | Logitech Z-5500 Computer Speakers
How to mount a bandpass sub
usually you will get the best sound with the box mounted approximately 3" away from rear of trunk with speaker facing toward the rear of trunk if it is a single speaker enclosure you want to do the same just offset it to one side of the trunk corners always amplify sound however just so you know 10's are not really made for low bass they usually have more of a hard hitting pound instead of a low rumble usually 12's will give you the low bass better and it also depends on what kind of box a vented box would be best for low bass sealed box gives you tighter bass but you need more power ported is good for low bass but gets sloppy when loud and a bandpass is used for loud hard hitting bass
Feb 27, 2010 | Car Audio & Video
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Dual voice coil speakers
best way to do this to preserve your amp and speaker is to wire the speaker Voice coils in series.
VC1 = Voice coil 1
AMP + to VC1 +
VC1 - to VC2 +
VC2 - to Amp -
Set you amps bass gain down very low. Crank up the volume with a bass test audio track. Turn the switch to LPF or Low pass filter. Adjust a LPF to about 60 hz Adjust the bass gain up until your Sub begins to sound sitorted or choppy. Then tune the bass gain just below where it distorts. Then you are set.
Dec 07, 2007 | Jl Audio 12W6v2 Car Subwoofer
Low volume bass
You need to look got the amp for the sub if there is not one there is notting you can do. If there is one then just turn up the gain on the amp.
If not there are some times the gain is on the radio in a setting and the only way to find that is to look in the user manuil.
Oct 15, 2007 | Kicker 05C104 Car Subwoofer
Volume too low
Perhaps the speaker cons got damp this would effect the sound output try and plug in a speaker to one of the outputs and se if the sound is better.
Aug 23, 2007 | JBL CREATURE II Computer Speakers
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
