Question about Azpen X1 Tablet 50911
TABLET WILL NOT CHARGE WITH ANY CHARGER - Azpen X1 Tablet 50911
Tablet will not charge
Assuming that you charger is not defective, and that you have no other electrical issues, then if your battery has been allowed to completely flat line, it may no longer accept a charge from the normal wall charger. Then you can try to trickle charge your tablet from a low voltage/current source, such as a USB port or a low power phone charger (5v/500ma). Try a trickle charge for 8 - 24 hours on your tablet. After that try your normal charger and see if it will now charge properly.
If that does not work, and you have previously ruled out your charger, then I would suggest contacting the manufacturer, as it is likely some other fault, either with the battery, or the tablet itself.
I post on behalf of HP.
Jul 31, 2015 | Tablets & eReaders
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
Tablet charger is 400mAh and Tablet battery is 4000mAh. is my charger sufficient ?
The charger is right for the battery. IF battery won't charge on it proper charger, the battery or charger is bad. Take it back or put out more $$$$$$$$$.
Aug 31, 2014 | Tablets & eReaders
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 | Nabi 2
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Azpen X1 Tablet 50911 Logo
171 people viewed this question
Top Azpen Tablets & eReaders Experts
 Mikey
Mikey
ray gallant
Outback Jack
Outback Jack
Are you an Azpen Tablet and eReader Expert? Answer questions, earn points and help others
