Question about CellPhoneTrek.com Kyocera Hydro XTRM Multi Color Ice Cream Cones Phone Case Cover
Stuck on ice app - CellPhoneTrek.com Kyocera Hydro XTRM Multi Color Ice Cream Cones Phone Case Cover
To get rid of App for Dancing on Ice
go in to the app store go to my apps depending which phone you have got then press installed app go down to the dancing on ice app click on it and then click on uninstall app should units the app
Mar 12, 2018 | Cell Phones
I am strying to download the ice age village updates. it says whoops your not conected to the internet. I pluged into my computer. what do i need to do?
First check that your iPad is connected to the internet in the settings, and to see if it is connected to your WiFi. check in the App Store if there is an update available for Ice Age Village, and if there is, then you can update through the App store. If that does not work, I suggest saving your game data through the Game Center and re-installing the app.
Feb 19, 2018 | Apple iPad Mini
Kyocera cell phone
Hi @Julie, please turn off the phone and remove the battery. Put the battery back in a couple of minutes then power on the phone.
Oct 29, 2017 | Cell Phones
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
Frigidaire refrigerator glhs38egsb0 ice maker freezing up
Hi - Is the wire signal arm in a stuck position or has any ice cubes stuck? If so, try turning it off and remove any ice cubes stuck to the wire signal arm or body of the ice maker and wait approximately 8 hrs. Should these suggestions prove to be ineffective and ice maker continues to freezer up, I recommend contacting a professional to properly diagnose and repair the unit.
Sep 29, 2012 | Refrigerators
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Electrolux ice maker bucket stuck
Probably the ice maker leaking caused by ice maker itself or faulty water valve. I would think you would have to let Ice thaw that's most likely holding bucket from coming out and then replace Ice Maker or water valve or both.
Aug 23, 2017 | Electrolux Refrigerators
The ice maker wont drop the ice
Try this pour Hot water in ice maker it may be stuck then see,if blades turn there could be something stuck in ice maker.write back (I had a piece of plastic bag get stuck on the rotateing blades that push the ice up to the drop tub underneath) I hope this works for you
Aug 29, 2010 | Whirlpool Refrigerators
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
CellPhoneTrek.com Kyocera Hydro XTRM Multi Color Ice Cream Cones Phone Case Cover Logo
278 people viewed this question
Top CellPhoneTrek.com Cooking Experts
john h
Terry
Terry
damaso r claudio
damaso r claudio
Are you a CellPhoneTrek.com Cooking Expert? Answer questions, earn points and help others
