Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
Door wont close
When I hit remote, door tries to close. I hear the motor actuate and can visibly see the door "****" but chain drive seems to be stuck in place. Door move manually without a problem and in going over the chain, it seems fine. Is the problem internal?
    Top Expert:
  • Chamberlain Master
  • 12,962 Answers
The gear wheel powering the chain is stripped. The cogs are usually plastic and not uncommon for them to wear or break off. Replaceable item from manufacturer.
Posted on Nov 28, 2013
SOURCE: Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Posted on Dec 17, 2009
blanchettohd
  • 143 Answers
SOURCE: Chamberlain hd900d garage door opener
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
Posted on Oct 11, 2010
  • 15 Answers
SOURCE: My door will not go
It is safety "eyes" sensor issue with your system. Lights flashing on the main console indicate a potential problem. Model up, from yours WD962KD, I believe, has a "smart" wall mountable remote that displays a potential problem. In your case, I would check that both safety "eyes" sensors are working (both should have lights on, one amber and one green). Post if you need more help.
Posted on Nov 01, 2010
  • 15 Answers
SOURCE: The opener seems to want to continue closing the
Try to re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
2manyhobbies
  • 128 Answers
SOURCE: Chamberlain Power Drive / Whisper
It sounds like the door is your problem.
Check the counter balance spring above the door. It is likely broken.
If the door cannot be operated manually, the garage door opener will not open it either. The machine is made to operate a door that works correctly. If the door is broken, the machine will not work either.
It also sounds like the opener gears may be worn out. That also occurs because the door required service.
Posted on Jan 03, 2011
Honda CRV-EX 2003: remote not working. Battery OK. Hear attempt to open or close but door buttons wont operate. Hellllp!!
If you have replaced the batteries in you remote(s), and you can hear the locks attempting to work, your door lock actuator(s) maybe faulty. The actuators are not expensive, but the labor to have them installed can be.
Dec 15, 2014 | Honda Cars & Trucks
2006 Ford Fusion right rear door will not lock with remote
Sounds like the electric actuator is not connected inside the door.
Aug 20, 2012 | 2006 Ford Fusion
I have a Craftsman 1/2 hp, mod # 139.53603. When I press the remote or the panel button there is a humming sound from the motor. I opened the panel on the back and did not see anything out of line, etc. ...
Is the trolley jammed against the bolt just in front of the motor? If so, loosen the chain until the tension is off the trolley and then run the motor until the door is closed. Now locate the up limit on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
My 1/3 hp craftsmen door opener just hums when you hit the wall button or remotes in the car. I replaced the starter motor capacitor and nothing changed any ideas?
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain until the tension is removed from the trolley. Run the motor until the door is closed. While the door is closed locate the 'up limit' adjustment on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Drivers main door lock won't acutate
{: ) If its only the driver door lock not working, open that door and try to put your ears as close as possible to the actuator area. You can use your remote to lock and unlock the door actuators. Can you hear the lock actuating even a little sound? Is the doorlock knob seem to move but wont push or pull thru? I hope you did. Because you just need to replace the actuator.
If thats not the case, it can also be an actuator, but you may need to confirm the wirings first.
Oct 20, 2010 | 2008 Chevrolet Suburban
My 20 yr. old Craftsman 1/2HP chain drive GDO (139.18590) will click and hum for a second but the door doesn't move when I press a remote or wall console. The door moves freely manually and I checked the...
If your door is stuck in the open position the trolley is most likely jammed against the bolt just in front of the motor unit. You should be able to loosen the chain enough that it releases the pressure on the trolley and then close the door. While the door is closed, locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover and then tighten the chain.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote doesn't work
check the drag link on lock assemblyit may be bent or the motor to actuate it is loose or broken
Aug 20, 2009 | 2006 Honda Accord
I have a craftsman garage door opener and the chain came off the track. I've put the chain back on the track wheel but i had to loosen the chain to do so. now, when the door closes the bar bows up and the...
The reason your door is opening again is because there is a limit switch that is not making contact at the appropriate time to tell the drive to stop closing the door. The chain drive motor is controlled by a circuit that is expecting to see a signal telling it that the door is closed. If it doesn't see this signal to stop at the appropriate time, it continues to drive the door down unless it sees a certain amount of back pressure, which then tells it to return the door to the up/open position. This is a built in safety feature for most garage door drives and is industry standard now due to children getting caught under them and being killed. You can try this yourself. Stick a 4 foot 2x4 vertically under the middle bottom of the door as it's coming down, after a second or two the door will reverse direction.
With the chain falling off the drive and loosening it to replace it, you may have inadvertantly positioned the actuator of the switch, which is usually attached to the chain, out of position by a couple of links. There is a momentary contact switch mounted close to the door on the support shaft of the drive mechanism. This support shaft is the one holding the motor drive on one end, along with the chain and is anchored to the header over the garage door. This momentary switch may have a short metalic or plastic arm hanging down that is moved by the actuator on the chain and needs to be reset to a position where the switch contact will be closed when the door is in it's closed position. There are other options also depending on how new/old your door drive is. Some of the newer models use a through beam sensor or photo eye as a stop switch.
Please let me know if this helps.
Backyard_Jim
Dec 31, 2008 | Washing Machines
Garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
70 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
