Question about Stihl Garden
My stihl ms 260 chainsaw wont idle down to low idle
I have cleaned the carb and linkages and adjusted the jets but it still idies to high
    New Friend:
It's most likely the clutch side crank seal.
Posted on Jan 02, 2016
  • 23 Answers
High idle is usually a sign of running too lean, or having an air leak around the carburetor mount, or even somewhere else on the machine. if turning the low mixture screw out half a turn or so doesn\'t help, I\'d start looking other places for a leak.
Check things like the plastic plate the carbie mounts to (intake manifold) and all the gaskets associated with that area.
Also, check your fuel lines aren\'t perished, they can cause air to suck up into the carbie and cause issues.
If you still have no luck it\'s possible one of the main crank seals may have gone, causing air to suck in around the crankshaft.
This is best left to a qualified small engine repairer to replace, as they can be dicky to get in there without damage.
Hope that helps!
Posted on Nov 19, 2013
2 Suggested Answers
  • 211 Answers
SOURCE: Stihl MS 260 Pro wont run wide open or idle.
Hi brandon First change the sparkplug with the same heat range,Check and clean the gas filter with compressed air.Remove the carb and very carefully disassembly entirely.Check the gaskets and the diafragms.At the fuel pump side there is a fine screen(clean it).Check the needle,the spring and lever.Unlock the screws L and H(note how many turns are they).Put the corp of the carb in a special clean solution for 12 hours and then clean it with compressed air(something is clogged there).Put all back together and try to start the engine. regards savumihai71
Posted on Feb 12, 2009
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Saw wont rev up or idle
First thing, try new gas.
If that doesn't do it, you need to adjust the low and high speed circuits on the carb. A good starting point is 1.5 turns out from fully seated. On that saw I'm not positive if you will have access to the adjustment screws unless you pull off the plastic caps that may be covering them.
Feb 01, 2014 | Stihl Garden
Husquvarna chainsaw carb adjusting
Hi Mark
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Nov 24, 2012 | Garden
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
Car settings stihl 026 with wt 194 carb?
Hi Alan Cowart
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
Sthil carb setting
Hi
Aug 24, 2012 | Stihl 019t, Ms 190t, 191t Chainsaw Rewind...
Have stihl ms 210 chainsaw cranks will idle boggs out when you give it gas adjust highspeed then want idle been threw carb twice its clean [ help]
if it is ideling ok I would check the air filter first , try running it without filter in clean air enviroment, Then check the spark plug, clean or replace if necessary, then attempt adjusting carb...
Dec 11, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Feb 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
376 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
