Question about Maytag Neptune MAH6700A Front Load Washer
Display board not working will not turn on - Maytag Neptune MAH6700A Front Load Washer
Hi..I recently bought a jazfit 5003 secondhand. It worked beautifully for a week. I turned it on today..but the console doesn't turn on. Any ideas?
19 Excahange the batteries old by new ones.
2) Tight the flexible cable for keypane vs display board
3) Tight the connector from display board to lower board.
4) Adjust the sensor reed switch bh 1/8" as show the diaigram
5)lsee the power output from main motor board is supplyin to display board the +5VDC.
See the block diagram for easy diagnostic and fix it.
sincerely. Merry Christmas
ernesto cuadra
Managua, Nicaragua.
Dec 22, 2011 | Exercise & Fitness
When turning reebok tr3 on the digital display goes off and green light stays on english led and treadmill doesnt work
1) Try to exchange batteries new ones.2) see the diagram adn adjust by 1/8" or 3mms according. 3) tight the key panel flexible cable vs display board 4) then connector display board vs lower board.5) test the main motor controller bOARDEC for 5+vdc, to display board.See the block diagram how the main motor controller has 90% aprox for control functions of any treadmills.sincerely. Merry Christmas.ernesto cuadra , managua, nicaragua. 12_20_2011_7_10_29_pm.gif12_20_2011_7_10_45_pm.gif
Dec 20, 2011 | Exercise & Fitness
My dash board milage light does not display
Probably a bad solder connection on the instrument panel between the led display and the circuit board itself. Instrument panel needs to be removed for this proceedure. Remove the back cover from the circuit board and carefully remove the circuit board to access the led display. Carefully lift up the display and look to see if any of the solder joints from the solder legs are loose. resolder as needed. Plug the circuit board in the dash and turn on the key to see if it works.
Apr 11, 2011 | 1999 Chevrolet K1500
Hi, the receiver has no sound when it turned on and the display is off as well, although the functions as output, channel selector are working. Appreciate your input for the problem.
SONY STR db840
No display:
broken trace on "Digital board" ,feeding 32v from "DC board" to "Display board"
solution: make new jumper btw. "CNS2" and "CNP4" on "Digital board"
Now display OK again : )
Sep 26, 2010 | Sony STR-DB840 Receiver
Ge repair man installed new circuit board worked ok for 30 days now open doors and says off in display, press minus button turns on for a while then turns off again. need help.
I would recall that GE repairman. Most likely the board he installed is defective. There is one in the display usually will not light at all when it goes out. Below is a link to that main board in the rear.
Main board
May 21, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Solved problem. Replaced main Control Board. Works like a charm, hopefully willl last like one too!
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Feb 13, 2009 | Canon Office Equipment & Supplies
Display intermittant for few weeks, now no display or oven control
real easy trouble shoot, check the wiring diagram out and find where the line voltage goes into the board. if you have voltage to the board and no display it is very likely a bad board also make sure you have ground pathway from the board. you can have voltage to the board but if no ground pathway then the board will not work. a cheapo meter from sears etc. will work
Apr 22, 2008 | Maytag MER5530 Electric Kitchen Range
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
Maytag Neptune MAH6700A Front Load Washer Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
