Question about Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4)
How to install Linksys 2.4 GHz 802.11b Wireless Adapter
tech curly
  • 298 Answers
SOURCE: lost ny disc for the Linksys wireless-G pci adapter 2.4 ghz
yes there is. you just go to linksys.com/download.
let me know if you need more help.
Posted on Jun 23, 2008
SOURCE: lost cd rom to download Linksys wireless G notebook adapter
two bad
Posted on Sep 30, 2008
kokuryukai
  • 8 Answers
SOURCE: unable to setup Linksys WUSB54GC wireless network adapter
The Linksys WUSB54GC isn't compatible with Windows Me, upgrade to XP or Vista. Minimum Requirements
  • 400 MHz or Faster PC
  • 128 MB of RAM Memory
  • CD-ROM Drive
  • Available USB Port
  • Compatible with Microsoft Windows XP, Vista, and Vista 64-bit edition
Posted on Apr 18, 2009
mukund_ce
  • 186 Answers
SOURCE: i lost my installation cd.
I will give you a easiest way for finding the drivers that you need for your hardware.Just download the software named driver magician.Install it and it will search for the drivers that is not installed for the hardware you have through internet and will download it for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
Posted on May 16, 2009
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Fitted a Linksys-g 2.4 ghz pci adapter to my kids pc, take make their PC wireless, installed the correct drivers after researching what these were on the internet and all ok. Changed ISP and no longer...
If your modem(the device given by your ISP) connected the linksys router on WAN port just power down all devices and power on modem and make sure all lights are on and then power on linksys router. This should fix most problems. If no luck connect your computer to modem directly and check if you are able to log on to internet! If your modem is not working then your ISP is the best option to call!
Sep 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
How do you configure a linksys wireless-b WPC11 notebook adapter to connect to available wireless connections?
let me tell you its very easy.
Follow these steps to connect your Linksys adapter to available wireless connection:-
1.With this adapter you must have received a disk of driver for this adapter.
so install the drivers disk first.
2.Once the driver disk install then now you can search for available wireless network name.
To search wireless network in xp:-
start>>control panel>>network connection
now look for your wireless network connection.>>>right click on it>>>left click view available wireless network>>>here you can see the available wireless network name and now try to connect to your network name
Follow these steps for vista and window 7:-
Click on start>>Above start you will have search box>>in the search box type connect to
Apr 08, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
I have defined 2 networks, one for the G and the other for the N channel, only the one for the G gets connected
You have WRT610N dual band router . it works on both 2.4 GHz and 5 Ghx bands at the same time.
Both the bands are N bands.
2.4 GHz and 5 GHz band are capable of working on N signals.
Now on your computer you are able to see only the 2.4 GHz signals but not the 5 GHz signals.
To see the wireless signal on the computer , your computer should have 5 GHz compatible wireless adapter.
If you have 2.4 GHZ adapter on your computer then you won't be able to connect to the 5 Ghz signal.
Open the Device manager and under network adapters you will see the wireless adapter. Check if it is dual band wireless adapter.
Click here for more information
Aug 04, 2010 | Linksys WRT610N Wireless Router
Adapter recognizes wifi but windows xp won't
it may need a Wireless Ethernet Password (WEP) key
Mar 16, 2010 | Linksys 2.4 GHz 802.11b Wireless - B...
I lost my CD Installer for wireless-G 2.4 Ghz
You can find the software that was loaded on the CD at the linksys website.
http://www.linksysbycisco.com/US/en/support/WET54G/download
Dec 29, 2009 | Linksys WET54G 2.4 GHz 802.11g Wireless-G...
Dell D600 - Linksys wireless router/adapter
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in 192.168.1.1 into your web browser and a login in screen should pop up.
Apr 28, 2008 | Dell Latitude D600 Notebook
Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4) Logo
60 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
