How to choose from different titles on series dvd with ub070 remote
Ub070 remote control
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
Can you use ONE FOR ALL URC-7544 remote control to operate any DVD?
Hello
No universal remote control have codes for all DVD player. You have to choose a universal remote control, that have codes listed to your device. Different models of remotes of different companys are intented to use with some particular model of devices. OK.
Aug 15, 2011 | One For All URC 7740 Remote Control
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
Require a code to unlock my Panasonic ntsc DVD A310u/ca. Also my Toshiba DVD SD100EE.
Put DVD into player - wait for regional code violation screen to appear. Once this happens press the M (Memory) button on your remote control. Then press 1 for Title 1 and press play on the remote. This will over-ride the regional code violation detection menu and you can watch the movie etc by entering the fwd on the remote control and change chapters etc by using the T (Title/Chapter) button on the remote control)----
This is the only unlock I can find for Toshiba DVD players, yours was not listed but I thought worth a go, I donn't have one for the Panasonic, sorry.
Apr 02, 2010 | Televison & Video
Have a Toshiba SD 220-E dvd p-layer & a dvd in it saying 'play restricted' can we unlock code ?
hi! i hope this code will help you unlock the region code of your dvd.
Jul 29, 2009 | Televison & Video
How do i unlock the region on a toshiba sd-2109 dvd player
Put DVD into player - wait for regional code violation screen to appear. Once this happens press the M (Memory) button on your remote control. Then press 1 for Title 1 and press Play on the remote. This will over-ride the regional code violation detection menu and you can watch the movie etc by entering the fwd on the remote control and change chapters etc by using the T (Title/Chapter) button on the remote control)
Jul 14, 2008 | Toshiba Televison & Video
Dvd-vr357
I do this all the time. Press Menu on your remote control. From there go to Copy then select VCR-->DVD. If you're recording from the beginning of a tape just press the Enter button. If you're recording from another place on the tape hit Play or FF to advance you to the spot you want to start recording. Stop the tape where you want to record from and hit Enter. FF to the place on the tape where you want your recording to stop. Stop the tape where you want the recording to end and hit Enter. Hit the Down Arrow on the remote control to highlight Copy All and hit Enter. Your machine will rewind to the start point and begin recording and it will stop when you get to the indicated end point. Note: If you have more than one episode/show on a VHS tape and you want separate titles for each, you have to go through this process for each title. If you have more than one start and end point for each copy command you'll just get different chapters not different titles. I hope that made sense!!! Hope this helps you out.
pjrsop
Apr 24, 2008 | Samsung DVD-VR357
Region free?Toshiba SD-140E
I found this for other Toshiba SD dvd players, yours was not listed but might be worth a go.
Oct 25, 2007 | Toshiba SD-140E DVD Player
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
