Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Washer won't come on at all
When I close the washer and press the start button, nothing happens
    Problem Solver:
  • 10 Answers
Is it plugged in? Is the breaker tripped?
Posted on Nov 17, 2013
I have Hotpoint Ultimate Extra WD72 washer dryer and the start button has stopped working any idea if this is an expensive problem ??
When you close the front washer door, it closes a switch. This switch prevents the washer from operating when the door is open. Your problem is when you close the door, the switch does not go into the closed position. Now when you press the start button, nothing happens. It acts as if the door is in the open position, even though the door is closed. The door switch is defective and needs to be replaced with a new one. Some start buttons only momentarily close and use a relay type of switch to keep power going to the washer. If you have this type of start button, then the relay/switch could be defective. This is a separate part, it is not the start button switch. It is also possible that the start button switch is defective. So up to three parts need to be checked. None of these are expensive repairs.
May 26, 2014 | Washing Machines
Roper washer don't start
That is still under warranty, you have done all that you can within reasons. Call Lowes.
Jan 24, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
one place you say 2013 then it is 2014 then later 2017. we can not assist you when even you do not know what it doesn't do oneplace it is admiral , then a roper call LOwes
Mar 01, 2017 | Admiral 3.4 cu. ft. Top Load Washer in...
Door doesn't unlock, won't start a program
it might just need an update,if not the main board could be going to fail hope not ,not cheep
Nov 03, 2017 | Zanussi WJD1257W Front Load Washer
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
Won't turn on
Try just pressing the selection pad, without pressing start/cancel and close the door. That has worked for me a couple of times.
May 05, 2010 | Frigidaire Professional Series 24 in....
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE3t wont start
open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Mar 21, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
