Question about Rainbow Technologies D4 Bagless Vacuum
Replace power cord on ranbow D$
The unit just died while in use. when my wife jiggle the cord (thinking it was not in the wall socket correctly) it momentarily ran again and then died. How do I replace or test the power cord/
  • Rainbow Tech... Master
  • 18,424 Answers
How do i remove the power supply socket from the dyson wall mount
Hi Les, it's Jack at Dyson.
The end of the charger cord assembly which attaches to the machine itself is held in place securely by a friction-fit connection. You should be able to use something like a flat-bladed screwdriver to free the end of the charger cord from the docking station. Then with the docking station removed from the wall, you should be able to disconnect the charger cord completely from the rear of the dock, following the route shown in the image below:
I hope this helps - if you'd like any additional advice you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Kirby doesn't always start when plugged in unless I jiggle the cord and then it often stops when in use.
You need a new power cord! :0) Here is a link to help with replacing it...
Jun 17, 2014 | Kirby Vacuums
My cord has to be pushed in to socket and giggled to get the vacuum to have power? Any suggestions?
You might want to remove the electric plug from the wall and spread the prongs just a little bit, it sounds like the plug might be loose in the wall socket.....try it in another wall socket and see if the problem continues to exist...generally it you get the same result from similar wall sockets...you may have looseness in the electrical plug...meaning that you might have been unplugging the cord by grabbing the cord and snatching versus unplugging with the plug itself. Hope this helps.
Sep 25, 2013 | Electrolux Guardian Bagged Canister Vacuum
Hoover S3765
If you light and nozzle motor both go off at the same time, you might have a bad power cord. Mine had this problem which I could verify by jiggling/twisting the cord near the strain relief on the nozzle. It would go on and off as I did this. The cord is cheap to replace, around $13 for the part shipped. Part number is 59134072.
May 30, 2012 | Hoover S3765-040 WindTunnel Bagless...
Euro-pro #S3101 doesn't turn on
Check in the following order.1. Plug unit in firmly in wall socket.2. Check fuse or breaker. Replace fuse/reset breaker.3. Check the continuity of the power cord.
Oct 30, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Hayden SuperVac 3600, almost 10 years old. The unit still runs, but now when I switch to the power nozzle, it doesn't have power to turn that. I think this happened once before and maybe they...
The hose has fuseable link inside, generally a 3-7 amp. It is at the wall end underneath the hose cuff. Easy to replace as it crimps in line. If you have a meter you can also test the detachable hose to wall cord for continuity, then check the hose to handle as well.
You can also detach the hose to wall cord from the hose, and plug your power head directly into that cord,, then into the wall thereby eliminating the hose itself.
Hayden makes a serviceable hose. If damaged or the fuse blown it can be serviced by a good tech. If the fuse is blown you need to clean and inspect the power head as this may be the cause
Jun 20, 2009 | Hayden Industries SuperVac 6000 Central...
Kirby Generation 3 no power...
I don't believe there are any service manuals online, as Kirby has service centers around the country. There are 3 things in the power string--on/off foot switch, the power cord, and the power assembly that the cord plugs into underneath the bag in the main part of the body. One of the problems the G3 had was where the cord plugged into the body--the assembly was a very thin plastic piece supporting the 2-prong electrical connection. This plastic piece was known for breaking, and was actually recalled back in the 90's. You can take the cord connection off and look to see if that piece is broken, then you'll have to take it in, or buy a "switch" as it's called on ebay or somewhere and replace.
Dec 29, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Power brush SEB234/236
Hi Clyde,
Before you start, unplug the vacuum from the wall socket.
First remove all the shoe laces from the beater brush. Then make sure the belt in installed correctly. If this doesn't correct the problem, open the unit and find any fuses that it may have and replace any that are blown. That sould correct your problem. It sure seems that vacuums get hungry for more than dirt at times. lol Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vacuums
DYSON DC05
My friends Dyson DC05 was loosing suction and then it stopped altogether one day. When she took the filters out there was black soot in them so it was obvious that the motor had burnt out. I think this happened because she wasn't cleaning the filters regularly (go do yours now!) I replaced the motor myself and wrote a guide with photo's at www.tasweb.org
Dec 11, 2007 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
Top Rainbow Technologies Vacuums Experts
Are you a Rainbow Technologies Vacuum Expert? Answer questions, earn points and help others
