Question about InFocus ScreenPlay 5000 Multimedia Projector
No green power light on
I have power to the unit but no green light is on. I try to power on but nothing happens. I was wondering if there was a fuse anywhere or if you can guide me to something else to check.
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Tevion LCD4203ID, turned televsion on by mains plug, no power being received by television. Have tried different mains adaptor so is definately television. There is no red light or green light on...
Sir try to check the fuse in the power supply may be damage. Remove the back cover of your unit but be sure to unplug the unit from the main ac outlet. Then look for the fuse, if the fuse is defective, before replacing it observe if the fuse is totally burned if you see this sign don't just replace the fuse it indicates that it has a shorted parts in the power supply common parts are the regulator and bridge type rectifier, but if the fuse is just broken or still you can see the wire you can replace it and try to check if the unit will power up. Good day and best regards.
Sep 04, 2011 | Televison & Video
My one year old 8000 BTU GE window unit will not turn on. The electricity was going off and on so I unplugged the air conditioning unit off. Now it will not come back on. The green light on the plug is on...
Is the display panel lit up? If not look for a fuse mounted on the board.Take the fuse to radio shack and get another. Unplug the unit before attempting to service it.
Jul 09, 2011 | Heating & Cooling
When I turn on my RV Air Conditioner either manually or by remote control, the on green light comes on, but nothing else happens. Even the fan will not work. Is there a reset button I need to try and...
Where is the green light that comes on? If it is not on the unit you may have a fuse or circuit breaker problem. check these if you hav ot already done so.
Jim
Apr 26, 2011 | Heating & Cooling
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
PC will not power up
Try to reboot your computer with the disk that it came with.=D
Apr 19, 2009 | HP Pavilion a350n PC Desktop
Standby light blinks 6 times
It is fuse issue again. Go to this website and you should have solution or ask for one:
http://www.avsforum.com/avs-vb/showthread.php?t=507602
Dec 18, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
i had the same problem to, i replaced the thermal fuse and everything was back to normal. Be careful if you are a gamer because both times this has happened i was playing my xbox
Nov 03, 2007 | Televison & Video
Broken ds
If you know any thing about electronics you can pull it apart and replace the power fuse inside of the unit right up next to where the charger plugs in. It is a little flat black fuse with a couple of numbers on it.
Oct 13, 2007 | Nintendo DS Lite Console
InFocus ScreenPlay 5000 Multimedia Projector Logo
56 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
