Question about Honda Generator Em5000is Em7000is Maintenance Kit air Filter, Plug, Manual
Engine surges from 3000 to 3600 rpm - Honda Generator Em5000is Em7000is Maintenance Kit air Filter, Plug, Manual
2000 Suzuki Esteem 1.8L.. I went to start my motor & turned it off right before started. I heard some kind of backfire. Then I started it and it's been idling high, the surging. Please help!!
scan it yet, a FULL OBD2 scan? why not?if not.
now is the time...
the 1.8L J18 engine, same as the older Sidekick sports used.
same engine , know it I do.
its the precursor to the J20, (j18 is under-stroked, j20 with many of the same parts. inside)
the back fire means explosion sound to rear end of tail pipe?
yes, that is rich raw fuel in the muffler. plus Air.
if there are exhaust cracks and then engine goes rich this can happen( a double failure)
if how ever BACK means, back to the Air cleaner, then that be different reasons, (timing)
engine now starts.?>
engine runs.? has full power, car drives ok.?
JUST?
SURGE,. you never said.
does engine get hot? 180F or more and holds (y/n)
ever get a full tuneup this decade,
most dont so i tell you, bad spark causes, misfire and raw fuel is wasted to the exhaust and sure can go boom.
surging usually means the ISC can not control idle
so it hunts, (a suzuki software engine on all 90s engines)
PCM errors, inside it. (dangerous too)
a modern car, if idle goes too high the ecu commands the ISC closed
and holds it there solid, (safe way , no hunting allowed now)]
so if this car surges, it's , lean engine.
some think flooding is surging.
and this is usually below 800 rpm,
almost stalls, then corrects, seems like a surge.
next time post rpm range of surge.?????
do not drive a surging engine, do not be like Toyota drivers. (over 800 rpm hot)
surge from 400 -800 rpm is class 1 surge.
surge from 800 to say 2000 RPM is class2, and very dangerous to some folks, (key off, get car fixed, tow it)
The ECU controls idle speeds. (hard coded servo controls)
Mar 18, 2016 | Suzuki Cars & Trucks
2002 intrepid engine surge at 4000 rpm at neytral and park.?
Be careful, could be dangerous, and similar to the Toyota problems before. Gas pedal and or linkage sticking? Last time serviced?
Feb 28, 2015 | Cars & Trucks
Car surging
Is the car equipped with the Automatic Transmission?
If so, read on.
Otherwise skip to the end and answer some questions.
POSSIBLE SCENARIO:
I have observed a condition where my car surges slightly when the torque-converter clutch (TCC) cycles between lock and unlock when driving on an uphill grade.
First some basics and history that will explain why the TCC is used.
Engine, Torque Converter, TCC, and Transmission relationship--
The TCC allows for a solid connection between the engine and transmission which allows the input to the transmission to rotate at the same speed as the engine.
Without a TCC, there is slippage between the engine and automatic transmission. The slippage is greatest at low engine RPM. That is what allows the engine to run with the automatic transmission in gear, like when you first shift into gear or stop at a stop sign. When the throttle pedal is depressed, the engine RPM begins to increase and the torque converter begins to slip less and less the more the engine RPM increases. The car moves. But even at cruising speeds the torque converter slips slightly. Engine RPM is greater than transmission input RPM, which is realized as slight decrease in fuel efficiency.
When acceleration is complete and a constant speed is being maintained, the engine power output is reduced to the point where the TCC can engage and eliminate any slippage between the engine and transmission. If the car has a tachometer the engagement of the TCC can be verified when a slight reduction in engine RPM observed without a corresponding change in vehicle speed.
One method used to test the operation of the TCC is as follows:
Find a flat section of road where it is safe to perform the test.
Reach a steady speed and keep the gas pedal depressed with one foot. While observing the tachometer (or listening for an increase in engine RPM), with the other foot depress the brake pedal enough to activate the break light switch but not enough to engage the brakes. When the brake light switch activates, the TCC receives a signal to disengage. With the gas pedal being held steady, release the brake pedal and the engine RPM should decrease when the TCC engages.
Old cars with Automatic Transmissions did not use a TCC. I believe the TCC was put in use in an attempt to increase fuel economy.
MY EXPERIENCE WITH SIMILAR SYMPTOMS
The condition that causes that issue on my car is this:
- A slight uphill grade increases the load on the engine.
The car tends to gradually slow and it is necessary to depress the gas pedal to maintain speed.
- Depressing the throttle pedal (manually, or automatically with cruise control engaged) signals the torque converter clutch to unlock when the load increases slightly. (A more drastic load increase would signal the Transmission to downshift to a lower gear.) The corresponding increase in engine RPM and output is enough to compensate for the reduction in speed. When the vehicle speed, engine RPM, and throttle position stabilize to the point that the TCC will engage and the engine RPM will reduce in correspondence with TCC engagement. Now, if the road conditions have not changed, power output is not enough to maintain vehicle speed. With the increased load caused by full engagement between engine and transmission, and the cycle (surging) repeats itself until the road conditions change.
Does that help?
If not:
QUESTIONS
Please define the symptoms.
What are the road conditions when the surge occurs? (A slight uphill grade?)
What is the frequency of the surge?
Does the engine power output have a noticeable surge?
Is there a speed change related to the surge?
Does the tachometer move up and down with little or no change in vehicle speed?
Are all instrument indication in the normal range?
What else has changed?
May 24, 2014 | Subaru Impreza WRX STi Cars & Trucks
Increase then decrease idle when engine is cold especially
cold engine idle surge. (problem)
RPM range of surge not stated
300-700 or 800 to 1500? (range is critical to diagnosis)
bad fuel
running summer fuel in winter (running old fuel?)
needs a tune up bad, see the list in the operator guide.
idle speed controller,sticking or EGR valve same. (clean them)
location not stated, so cant guess about local air temps.?
no other symptoms, lack of engine power? etc?
was it ok last week, or better, when was the last time it was OK?
1week, 1year?
surge , causes, on a tuned engine might be:
1: too lean. so lean the ISC can not control idle. rpm low, stalling
2: too rich, flooding, stalling, spark plugs foul (look at them)
3: weak compression in 1 or more cylinders.
4: bad spark.
5: air leaks, in the plenum causing , ISC to lose control.
why high RPM?
especially?
well that means it fails hot too.
and there is a simple tests. for hot surge.
is engine fully hot? 180F and holds solid there?
say rpm is about 800
and you turn on head lights, heater fan and (not AC) and defrost.
the RPM must hold or the ISC is failing.
ISC -= idle speed controls. (all EFI has this function)
Oct 28, 2013 | 1996 Honda Prelude
When I start my 1999 honda CRV it surges to about
no the surge that high is not normal a normal cold start should go to around 1500 then settle slowly to 750 or so but this all depends on engine temp and ambient air temperature
Feb 07, 2010 | Honda CR-V Cars & Trucks
Engine surges under load at 3800 rpm
yes it could be. have fuel pump pressure tested, fuel pump pressure should be. (key on engine off) 1999 to 2000--with egr--41 to 47 psi without egr--52 to 58 psi,
May 30, 2009 | 1999 Pontiac Grand Am GT
Engine surges at rpm over 1500
Look for a vacuum leak (lines and intake), Is the engine light on, were any codes present? A faulty EGR or IAC could cause the problem too. Check the throttle cable for any restrictions.
May 27, 2009 | 1996 Chevrolet Cavalier
2001 Toyota Celica GT RPM surging at Idle
Certainly sounds like the o2 sensors have become contaminated and are not acting as fast as they used to , or are supposed to.
Apr 24, 2009 | 2001 Toyota Celica
Rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Feb 07, 2009 | 1997 Chevrolet Astro
Honda Generator Em5000is Em7000is Maintenance Kit air Filter, Plug, Manual Logo
18 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
