Question about Hemera Computers & Internet
Printing hemera pictures
What is the copyright information for using hemera pictures
Is it possible to retract a photo I posted on Facebook?
as you are identified in it , it cannot be used without your express permission regardless if copyright or not
Sep 10, 2017 | Facebook Social Network
Hemera The Big Box Of Art
What is the error you are getting?
Jun 26, 2008 | Hemera The Big Box Of Art for PC
Serial number for hemera photo objects
if you purchased genuine software, you will have the serial number. i suspect you have a pirate copy. contact company to get serial.
Jul 14, 2012 | Hemera Computers & Internet
Hi, Can you show mw how to preview Hemera Photo-Ob...
in the cd1 you can found an install for macintosh, tip: use any name and password
May 20, 2010 | Hemera Photo Objects 50,000 Vol 1...
Installing Hemera Photo Objects on a new computer
First, copy all the CDs to a location on your hard drive.
You now need to use Preferences within the Hemera Image Browser - choose Search Folders and then press Add - to manually add each HPI folder. You'll find these inside the CD folders for each CD. Then it will work.
Apr 15, 2010 | Hemera Photo Objects 50,000 Vol 1
Printer doesn't print exact copy of picture should be in color.
Is the setting on the print driver set to color? If so, often times you can't print certain imaged from the web as you see them, It is copyright protection. So it may not be possible to reproduce is as seen.
Jan 31, 2009 | Office Equipment & Supplies
Can't open file.
Check Hemera settings and ensure that the path for the picture files is the right one, where files are stored.
Hemera usually reads the picture files from CD/DVD unit, if your system had renamed the DVD form D:\ to E:\, for example , then Emera wont be able to find files anymore.
Solutions to this problem.
Check file source folder on Hemera settings, and assign the right CD path.
Do a system restore to a date before having the problem.
If still no luck, then Windows may be corrupted, in that case , the standard procedure is reinstalling Windows, then reinstalling Hemera, and the rest of the software.
Jan 02, 2009 | Hemera The Big Box Of Art for PC
Nikon D40, how to display the date.
Select play back menu and select print time stamp.
For your Knowledge,do you like or not
All photographs taken with this camera having a data file with it, called meta data. All these file in formation can be viewed in clicking file info in photoshop.
The Metadata tags defined in the Exif standard cover a broad spectrum:
Mar 18, 2008 | Nikon D40x Digital Camera
Henera The Big Box not exporting pictures
I had the same problem on my XP Media Center system. Some of the graphics either appeared to be all white, or they were like 99% white and you could faintly see the center of the image if you moved the mouse around.
Hemera has a fix. They call it a "faded image" problem.
It involves downloading two files. One is an updater. The other is a zip file that, once the contents are unzipped, you copy to the location where the first file was installed to.
See:
http://support.encoreusa.com/product.asp?id=2221
Oct 09, 2007 | Hemera The Big Box of Art: 1 Million...
Computers & Internet Logo
14 people viewed this question
Top Hemera Computers & Internet Experts
David Payne
David Payne
Are you a Hemera Computer and Internet Expert? Answer questions, earn points and help others
