Question about Golden Technologies Electric Power Recline 3 Position Riser Lift Chaise Easy Motion Recliner Chair - PR-501M Comforter Medium 375lb Capacity
Lubricating life chair
My lift chair is making creaking sounds when raising and lowering but is still working ok. Does it need to be lubricated and if so, where and with what kind of lubrication?
    Scholar:
    New Friend:
  • 61 Answers
Most manufacturers have a lifetime warrantee on the frame. You would have to check and see. If you decide to just oil the joints the get rid of the squeaks, the best oil to use is either 3 in 1 or sewing machine oil. They are light and don't have a strong smell
Posted on Dec 15, 2013
  • timothy collier
    timothy collier Apr 16, 2016
    Here's what Golden Lift Chairs recommends: The manufacturer has a "lift chair service guide" available for download: REVA_082012. On page 48 It shows the points to lubricate and the two types of lubricant to use: Zep2000 on the Scissor Mechanism, and White Lithium Grease on the Lift Frame.
Chair does not raise or lower evenly
Lubricate the mechanism with a spray grease...not oil. You can obtain spray grease from an auto parts store.
Nov 19, 2014 | Home Meridian Comfort Lift Recliner
Makes creaking noise when lifting & lowering
Bolts loosen up a lot on these turn it on it's side and operate to see where it is binding. If you need Parts Home meridian...........
Apr 07, 2013 | Home Meridian Comfort Lift Recliner
Knoll Life Chair Making Noise!
use grease. wd40 is a penatrant not a lube
Mar 14, 2013 | Cars & Trucks
Knoll Life Chair making Noise
Check all screws for wear, tear and tightness. Replace stripped fasteners....
Mar 14, 2013 | Health & Beauty
My chamberlain liftmaster works fine but when I open the garage it makes asqeaking grinding sound. what should I do?
the rails on the door frame that the door follows to raise and lower need lubrication,clean rails thoroughly then use a light weight grease and lube the rails and oil the rollers on the sides of the door that follow the rails,also oil the screw or chain that raises and lowers the door from the operator unit,this will make them operate easier and quieter
Apr 09, 2010 | liftmaster Chamberlain Garage Door Opener...
Creaking sound in a rocking chair
Hello. The creaking sound is caused by the fact that some of the glue has dried out making one or more of the joints loose. To remedy this, go to any hardware or home depot and get a glue injector filled with polyurethane glue. here is a web link that will show you all of the details: http://www.ehow.com/how_5342197_repair-loose-chair-joint.html
Please rate my answer. thank you.
Jan 11, 2010 | Better Living SPP High Efficiency...
The crank to raise and lower the blade on my powermatic 66 is really hard to turn, any suggestions?
The square tooth screw and nut tend to fill with sawdust, which saturates with oil to cause the threads to bind (like a dirty nut and bolt.).
Clean the bolt with a cleaner, then apply a little wax to the threads (crayon or bees wax). Be sure to run the assembly up and down to cover the whole "bolt" and make sure to apply to the point of the screw that assures some of the wax works into the nut.
Wax is less likely to cause wood dust "mud" that WD-40 or other lubricants would cause.
Check the slides or guides that guide the assembly as well. CLean and lubricate with wax as needed.
Let me know what you find out.
Dec 12, 2009 | Powermatic 1660804K 66 10" 5 HP 3 Phase...
Delonghi Magnifica Makes creaking noise when preparing brew unit
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
May 19, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Golden Technologies Electric Power Recline 3 Position Riser Lift Chaise Easy Motion Recliner Chair - PR-501M Comforter Medium 375lb Capacity Logo
992 people viewed this question
Top Golden Technologies Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Golden Technologies Furniture Expert? Answer questions, earn points and help others
