Question about Refrigerators
Does the thermostat wire hang loose or does connect under the freezer on a haier mini fridge?
5 Suggested Answers
  • 531 Answers
SOURCE: Haier mini fridge runs very loudly!
some thing is wrong
Posted on Apr 07, 2009
landsend
  • 1066 Answers
SOURCE: haier fridge- freezer fine, fridge not getting
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
  • 72 Answers
SOURCE: Air or gas leaking from freezer in Haier mini fridge
If you go to a refrigeration supply the sell an epoxy to repair the evaporator but you will need to do a sealed system repair
Posted on Jun 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Which wires go wear when installing a new
In a mini fridge there are only two wires to the thermostat. I really does not matter which wire goes were because all it does is turn it off and on. Sea Breeze
Posted on Aug 26, 2009
Mini fridge not getting cold,freezer only gets cold?
If it's less then a year old you have a warranty, if it's older you are better off replacing the unit as direct parts are not available and subs would cost more that the unit.
Mar 24, 2013 | Haier Refrigerators
Tip
How to Replace a Thermostat in a Fridge?
If there cooling and defrosting problem in your fridge. Also over cooling or not getting cooling properly problem. Then the problem relates to thermostat.
The procedure to replace the thermostat is as follows: ---
1) First of all unplug the fridge/refrigerator unit from electrical outlet for complete safety.
2) In top freezer and bottom refrigerator model units. The thermostat is located at the rear of freezer side. But in some units its located in the bottom of the refrigerator floor panel.
3) In side-by-side refrigerator the thermostat is located at the back of the freezer side.
4) To remove the thermostat you will have to remove the screws from the icemaker section located in the freezer section.
5) After the screws from the freezer’s inner section are removed. The inside panel will get loose and come out.
6) Many a time the screws are hidden under rubber type butches. So its bit hard to locate the screws. So check out properly that all the screws in the inner section are properly removed.
7) After the inside panel of the freezer section is removed. You will see the thermostat. It has wires connected to its terminals. Be care full that you don’t pull out any wires. They are very thin and delicate wires.
8) The wires are connected to the thermostat by a connector. So slowly remove the connector from the thermostat using a needle nose pier. Take care you don’t put any force while doing this. It’s very delicate but not very hard to do.
9) After the wires are removed. Remove the screws holding the thermostat .In some models the thermostat is screwed to evaporator coil tubes. In that cases take care you don’t damage the tube while removing the screws holding the thermostat.
10) Before removing the thermostat take care you note down the position of old thermostat. so after the old thermostat is removed out by removing the screws. Place the new thermostat in the same exact position.
11) Refit all the parts which you removed while removing the old thermostat in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Refrigerators
Sides of Haier Compact Fridge are very hot to the touch
On some small units such as this, the condenser coil is actually in the walls of the cooler. It is not that unusual for this type of construction. I have seen this in chest freezers and other such units. If the unit makes the desired temperature, I would watch it for a day or 2 before putting any product into it to ensure it is okay and so you don't loose any product.
Sep 06, 2017 | Haier HNSE045 4.5 Cu. Ft. Capacity Compact...
Haire mini fridge wire is showing on inside
there is a temperature probe that does not connect to anything .should be in the freezer section tho
Jun 24, 2012 | Haier HSB03 Compact Refrigerator
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Which wires go wear when installing a new thermostat in my mini fridge?
Aug 26, 2009 | Haier HSA04WNC Compact Refrigerator
My Haier compact frig runs all time, at #1 setting: freezes all
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Jul 05, 2017 | Haier HSB03 Compact Refrigerator
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
