Can not remove base stem from 39 inch legend television
  • 3,904 Answers
Should be four screws holding it on under a plastic vanity cover. Probably take a small screw driver to access mounting area.
Posted on Nov 18, 2013
Need to remove base on nAXA Model NTD-1354
I needed to do this as well. The round part comes off but the stem does not come out of the TV. I don't mind taking things apart so I removed the screws on the back all around the frame. There are two screws right above all the hookups that you don't have to remove. After removing the screws, carefully separate the two halves. They snap togetther together on the middle of the sides. It takes a little effort to unsnap them I just kept running my fingernails up and down the seam until it popped apart. The screen half come off and is connected with some wires so don't pull it to far apart. At this point you can access the two silver screws that hold the stem in place. Remove the screws and the stem can be removed. Now snap the two halves back together (being careful not to pinch any wires) and re-apply the screws. I saved all the parts for the base in case I needed to put it back together. Last note, opening anything like this may void any warranty.
Aug 14, 2013 | Naxa 13.3" NTD-1352 12V HD LED AC/DC...
Water leaking at handle when turned on
1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
If not please go to step 2 in removal of stem
2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
May 19, 2010 | Kohler Fort© Widespread Lavatory Faucet...
How do you remove the stand of a grundig gu22wdvd3 so we can put it on a wall bracket ; it has the holes for a bracket to fix into.
First remove the two screws from the underside of the base, pull the oval base clear from the stem. This will reveal two screws within the stem, remove these and the four on the back of the stem. Job done, hang enjoy.
Nov 15, 2009 | Grundig GU22DVDPX 22 in. LCD TV
How do I remove stand from Hitachi HIT19WDVB digital LCD TV
THE CIRCULAR BASE OF THE STAND CAN BE REMOVED BY PRESSING IN 4 LUGS UNDERNEATH THE STAND AND THEN REMOVE THE CICULAR BASE.THIS GAINS ACCESS TO A SCREW AT THE TOP OF THE "stem"LEFT SIDE.REMOVE THIS AND THE STEM CAN BE TWISTED OFF GENTLY.
Oct 19, 2009 | Hitachi Televison & Video
How do you remove the base from 42 INCH OLEVIA
on my tv (42 inch) there are sixteen screws on the middle set up in four rows of four each. these are about two or three inches long.
take these out and the base comes off.
hope this helps.
Jun 15, 2009 | Olevia LT42HVi 42 in. LCD Television
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
Harley Rdkng FLHPI police seat air suspension mechanism removal.
There are two screws below the rubber stem fixed it to the frame. You can hardly see them from any angle but can reach them through the two round openings next to the stem. Use a small wrench, through the openings, to access and remove the screws, then you can remove the stem. However, keep the entire police seat assembly since you might want to put it back like what I am doing now. I tried serveral Harley and other brands seat, high or low profile, and found the police seat is the most interesting seat to ride with.
Dec 10, 2008 | 2006 Harley Davidson FLHR Road king
Moen single tub shower handle insatll
The valve has a faceplate that attaches with two screws and depicts the hot and cold mixing scheme on it. in the center of this is where the valve stem is located. It has a chrome escutcheon that slides into the faceplate and over the stem.There is a small -U- schaped clip that slides into the top of the valve body where the valve stem is seated that retains the valve stem. With all this in place all you have left is the acylic handle that has a unique shape to it on the internal portion that corresponds to the shape and position of the valve stm. Align the handle and stem and push the handle on. A small screw goes into the center of the handle to attach it to the valve stem. LASTLY you should have the acrylic button that covers the screw holding the handle on. All you do is align it appropriately and push the button onto the handle. The chrome handle version is essentially the same but is retained by a small allen screw on the underside of the base of the handle. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Oct 22, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Feb 24, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
