Question about Golden Technologies Electric Power Recline 3 Position Riser Lift Chaise Easy Motion Recliner Chair - PR-501M Comforter Medium 375lb Capacity
My lift chair is making creaking/clicking sounds when being raised or lowered. It still works fine but makes the noise.Does it need lubricating and if so, how and where? cmae915@yahoo.com
Why does it make a crunching noise?
Your chair is NEW! So, return your chair to the store where you bought it and complain!
Aug 01, 2015 | Furniture
Chair does not raise or lower evenly
Lubricate the mechanism with a spray grease...not oil. You can obtain spray grease from an auto parts store.
Nov 19, 2014 | Home Meridian Comfort Lift Recliner
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
Lubricating life chair
Most manufacturers have a lifetime warrantee on the frame. You would have to check and see. If you decide to just oil the joints the get rid of the squeaks, the best oil to use is either 3 in 1 or sewing machine oil. They are light and don't have a strong smell
Nov 17, 2013 | Golden Technologies Electric Power Recline...
Makes creaking noise when lifting & lowering
Bolts loosen up a lot on these turn it on it's side and operate to see where it is binding. If you need Parts Home meridian...........
Apr 07, 2013 | Home Meridian Comfort Lift Recliner
Knoll Life Chair Making Noise!
use grease. wd40 is a penatrant not a lube
Mar 14, 2013 | Cars & Trucks
Delonghi Magnifica Makes creaking noise when preparing brew unit
These machines do need to be lubricated every so often. First, buy some food safe lubricant, e.g. here. Then, turn the machine off, open the front door, and remove the infuser. There is a holder connected to the machine by two hex screws. You may remove this (or even just leave it on). Now attach a long tube to the lubricant (should come with the can) and spray lubricant on both sides of the vertical screw that moves the infuser up and down. Give it a few good sprays on both sides of the screw, up and down, and that should solve your problem.
May 19, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Creaking sound while turning steering wheel
There's a chance that the ball joints need grease. This should help, however once they have started to make noise like that due to lack of grease, they usually have gone bad. Replacement may be the only remedy. Hope this helps.
Oct 27, 2008 | 2001 Dodge Durango
Golden Technologies Electric Power Recline 3 Position Riser Lift Chaise Easy Motion Recliner Chair - PR-501M Comforter Medium 375lb Capacity Logo
381 people viewed this question
Top Golden Technologies Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Golden Technologies Furniture Expert? Answer questions, earn points and help others
