Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I have a 46 inch Sony Bravia. It is several years old. Maybe 5? A few years ago the screen was replaced under the extended warranty we bought from Target. The problem started out as shadows on the screen. They would eventually go away after the Tv was on for awhile. Now the center of the screen is black. You can see the picture on about 6 inches of each side and the audio works fine. Any ideas
  • 27 Answers
Bob,
It sounds like your screen has gone bag again. I hope you still have the extended warrenty .If not, the screen replacement likely costs more than a new TV and yours has a bad history.
Posted on Nov 17, 2013
  • 29 Answers
Is it a perfect square like there is a box on the screen ? if so it could be an easy fix if not then time for a new TV!! Did it just slowy get worse or was it just like that one day?
4 Suggested Answers
  • 4234 Answers
SOURCE: Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
Posted on Jun 11, 2008
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Posted on Nov 23, 2009
Testimonial: "You were so right. Thanks."
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
I have a 46" Sony Bravia. Approx 5 years old. Screen was replaced a couple years ago under Target extended warranty. Now the center of the screen is black. Audio is fine and you can see the picture about 6...
I have a "Home-fix" for you, you should watch this you tube video on how to repair a symptom such as yours even though it is a sanyo tv the fix is pretty much the same for your television and may save you oodles of money!
http://www.youtube.com/watch?v=purk_SyiT44
Good Luck!
Rich Lilja
Nov 17, 2013 | Sony BRAVIA KDL-46S2010 46" LCD TV
Sony bravia kdl52xbr2 problem
hi,hoping that the cable connections are right(check the cable connections once again)..... Sounds like you may have a problem with the video driver boards? I would call up the store where you bought it and ask for a new set or service on this one.
More than likely this is a bad display (lcd screen) the drivers in the lcd display have some problem...... the tv is just a month old so you are still under the warranty period....... just contact the sony outluet where you purchased or the manufacturer for servicing of tv
Oct 24, 2007 | Sony BRAVIA KDL52XBR2 Television
Sony bravia kdl-46w4100 moving vertical lines
Check the main filter capacitors at its power regulator board. Replace if found bulged or damaged. Replace all secondary side supply rails' filter capacitors too. The fault is with damaged electrolytic capacitors at the power regulator board itself.
Jun 06, 2012 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
May 19, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Dan
Jun 11, 2008 | Sony BRAVIA KDL52XBR2 Television
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
