Question about Intel Computers & Internet
Intel nh82801gb When i start my computer after the few days, it did not give me display, i got the message " no display" on my monitor. I have no graphic card. my monitor works properly, also i check my RAM & processor on another motherboard, but they are working properly.
Panth3on
  • 71 Answers
SOURCE: No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Posted on Oct 01, 2007
bunnydawg
  • 5158 Answers
SOURCE: My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Robert
Posted on Aug 28, 2008
emissionwiz
  • 75822 Answers
SOURCE: No display on monitor but my graphics card is working well on my other pc.
Yes this is a motherboard problem.
Posted on Dec 17, 2008
Mr BrokRench
  • 1623 Answers
SOURCE: graphic card for GA-8IPE1000 series
Your board has an AGP 8x inteface slot, the ATI Radeon 9550 graphics card has a RAMDAC Clock Speed of 400 MHz and 256 mb of DDR SDRAM memory onboard, would be a good upgrade, for about 60 bucks. Your board has 4 memory slots and will support up to 4 gigs of ram.(you will need a 450 watt power supply )
For best performance, memory should be installed in pairs.
CRUCIAL 2 X 1mb Part #: CT2KIT12864Z40B • DDR PC3200
would be a good choice.
Hope this helps...and answers your queastion.
Posted on May 27, 2009
SOURCE: my computer is not showing display
if the cpu is working and monitor also too
then change the batter in mother board
i 2 got similar prob recently
Posted on Jun 10, 2009
Display issue
Good day!
go to display settings then click on monitor tab change graphic monitor to Generic PnP monitor or the installed VGA driver on your computer.
Mar 28, 2014 | ASUS X55C-XH31 15.6" Laptop
Nh82801gb drivers
http://download-drivers-free.com/free-intel-nh82801gb-driver-download/
Jan 12, 2014 | Intel BIOSTAR Mainboard Support processor...
Monitor works fine but only shows image if turned on with computer startup
U have incompatable ROM problems,the E machine have different manufacture does related to the Intel corp.Most monitors has Intel compatabilies chips in it design,that why all regular computers have a video card or used internal computer Mem.video will work together.Uplug the E machine take the computer a parts take out the lithium battery out for a day or so.Put back the lithium battery back to your E machine computer now it should recognize the monitor again and work now the ROM are resetting and rebooting.
Feb 19, 2013 | Computers & Internet
Reasons of y signals not going to the monitor
Is the monitor showing a blank screen or is it showing the message NO SIGNAL??
If you have a Desktop try the steps below:
If it is showing the message NO SIGNAL, then the video card in the computer is bad, because when the monitor is bad, it will show nothing at all. To isolate the problem plug another monitor on the computer and see if it displays. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original Monitor is bad. If the Borrowed monitor displays the same as your original, then the video card in the computer is bad.
If it is a laptop try the steps below:
May 24, 2012 | Intel Motherboard
Where i can get audio driver for intel nh82801gb
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=4025811&lang=en&cc=us&prodTypeId=12454&prodSeriesId=4025810&taskId=135
Feb 15, 2010 | Intel Premier Resources 4-Channel 32-Bit...
Viewsonic monitor not detected after service
If you are running DVI-D(the white connector) then it isn't getting a digital handshake. If you have inspected the connection between the 2 and make sure there is no bent pins inside the connector that it mates with. If you have another computer, try to connect to that one.
Open windows start menu, right click on my computer, then choose properties. Next choose Hardware, then Device manager. Once there, double click on display adapters to see if installed correctly. If good, click Monitors. If good, then your video card driver must need reinstall or update as usual. Also do you have the correct driver for you monitor? How does it react when you uninstall the monitor driver(can you select 32bit and higher resolution in default drivers?
If none of this works, I would suspect that the replaced component failed due to static or faulty components within the electronics.
Is there any other changes to the PC (new video card, updated Directx9.0?)
Hope this helps and let me know if I can be of anymore assistance?
Aug 20, 2008 | ViewSonic Computers & Internet
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
