Denon rcd-m37 cd does not start
My denon rcd-m37 does not play cd's, when you insert the cd it will spin slowly for a short while and then just stops without playing any tracks
cdj repairs
  • 68 Answers
SOURCE: Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Posted on Dec 13, 2008
SOURCE: CD tray not opening on Denon RCD-M35DAB
there are tthere are two transparent plastic switches under the tray
there (a gray plastic piece, intcasing the loading motor is nonot rotated enough, not allowing the necessry pressure on the switch.
you must in either case disassemble the reading module comprising the tray, otics annd spindle, so you gain access to the underside of it, from ence coperatrepositioning the tray or the lrotating the trigger\eloading motor.
Posted on Aug 03, 2009
SOURCE: NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Posted on Oct 06, 2009
SOURCE: CD player acknowledge CD, starts to play, then stops
replace belt in lazar assembly and clean lazar eye with quetip with rubbing alchol
Posted on Oct 07, 2009
SOURCE: in just brought a denon m37 dab. but it will not
Hi, I have had exactly the same problem, I have tried three different M37DABs and three Believe CDs by Katherine Jenkins. Unfortunately I dont have a solution, but thought Id let you know its not just your CD player. I hope this can be resolved. Let me know if you ever resolve this problem. Thanks
Posted on Dec 10, 2009
I have a Denon DCD820 from the late 80's. This week I wanted to reuse it after remodeling my house and putting it aside for one year. When inserting a cd, sometimes it starts spinning and the shows the...
Couldn't find much for that specific Denon model but there is lots of info on basic CD player trobleshooting. If this video isn't helpful, do a youtube search or google "cd player troubleshoot"
Jan 08, 2015 | Denon Audio Players & Recorders
Tip
Denon VPROT Problem.
I posted a question regarding a Denon RCD-M37 DAB, which after a repair to the sub power supply transformer, came up with VPROT after a few mins use. After very careful measurements I found that the -12Volt line coming from the power regulator board situated behind the mains transformer was measured at 10.5Volts. It is necessary to replace the LM7912 regulator. Whilst with this board out check soldering and all other components. Normal operation has now been restored. I hope this will help regards Paul R.
on May 08, 2015 | Denon Audio Players & Recorders
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
What type of sub-woofer can i add to my denon rcd-m37 system? (passive or powered). Is this information free or not.
Free or you can tempt us with $$. Your choice.
Register and download the manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/rcdm37.html
Self-powered would work but it would have to run on full-range amplifier (from the speaker posts) or Line Level signal (from the OUT RCA jacks) because this unit has no Sub-specific output. It's no bigge as the sub would naturally discard the higher frequencies via its own amp's and speaker
Feb 22, 2011 | Audio Players & Recorders
My Denon M37 just cut out whilst playing a CD - what is wrong? When I switch the power off, then on again, it says Please wait........ then phases out again.
ONLY while playing a CD, or is excess volume at play, too? What about FM?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 06, 2011 | Denon Audio Players & Recorders
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
In just brought a denon m37 dab. but it will not play a new cd i brought to play in it. the cd is Believe by Katherine jenkins
Nov 22, 2009 | Audio Players & Recorders
I have a Denon RCD M33. It will turn on no problem but as soon as I press the eject button so that I can insert a CD it turns itself off.
I had to press all the eject, play and stop buttons simultaneously whilst at the same time pressing the on button.
Apr 11, 2008 | Denon Audio Players & Recorders
Platter quit spinning
Sounds like the motor drive controller might be malfunctioning. An authorized Denon service center would have to take a look at it to make sure.
Apr 08, 2008 | Denon DN-S3500
61 people viewed this question
 Grubhead
Grubhead
