Question about Hunter Dryers
How to bypass a limiter on a fan
The light are flickering how to by pass the limiter
    Genius:
  • Hunter Master
  • 1,617 Answers
Don't think you can.
Posted on Nov 21, 2013
Replaced cfl bulbs, but the flicker for 15 sec before starting.
Do you have a receiver in the fan or is it direct wired? If it is direct wired and there is no dimmer on the wall it may be a light-limiter issue. Fans roughly 2006 and newer have a limiting device in the light circuit. When they start to fail they are known to flicker or go dead completely. If you find a light limiter most people remove it.
May 03, 2016 | Dryers
Added a ceiling fan light kit .when I turn the switch on the light blinks once the goes off
Thanks to the DOE all ceiling fan light kits include a wattage limiter to make sure you don't waste energy by using too big a light bulb(s).
This limiter may cause the lights to blink or eventually both the fan and the light stop working all together.
There is a video showing how to bypass the limiter here:
https://www.youtube.com/watch?v=7WeWSKNe64A
If you are unsure about how to do it find someone who is capable of making the repair to be safe.
Feb 02, 2015 | Dryers
Is it dengerous to bypass wattage limiter
What do mean "wattage limiter"? Do you mean a dimmer switch? If so, what do you mean by "bypass"? Your bulbs (if in USA) are rated for 110-120 volts, and use whatever wattage they say they are rated at. Wattage is the amount of 'power' consumed. By "bypassing the switch", I assume you mean direct wiring them. IF so, they will only use whatever they are rated at.
Sep 29, 2014 | Hampton Bay 24002 Ceiling Fan
Lights flickering
The capacitors have nothing to do with the light kit. Are you putting in the correct wattage?
Oct 20, 2013 | Dryers
Engine light on
hi check the battery is holding its charge / if the engine light flickers it may be the fan belt/ also check the alternater
Apr 19, 2010 | 2007 Hyundai Entourage Limited Minivan
I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
BRIVAS DUCTED HEATER FAN RUNS BUT NO HEAT
It sounds like a bad or tripped limit switch. The limit switch is a small disk about the size of a penny with 2 wires attached. There will be a small button between the two wires. Press firmly to reset it. Depending on your unit there could be 2 to 5 of them to reset. If they aren't tripped, then one by one, take a small jumper wire and jump them by bypassing them. You will eventually come across the "bad" one. If you can't reset it, then you will have to replace it. There is also a limit that can not be replaced that is located on the heat exchanger wall. Bypass it only temporarily to see if it is bad as well.
Apr 06, 2009 | Heating & Cooling
Dryers Logo
88 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
