Question about Mitsubishi Lancer 09 2009
Locating diagnostic link connector - Mitsubishi Lancer 09 2009
  • Mitsubishi Master
  • 1,975 Answers
locating diagnostic link connector - 8424c2e8-6320-4b1a-a4b3-696ee18bba73.jpgHope this helped......
Posted on Nov 18, 2013
How do you read codes on a 91 dodge ram charger there is no ob2 plug in?
Data Link Connector
Print
The data link connector is a dedicated diagnostic scan tool connector. It is located in the engine compartment against the fire wall. It links the engine controller to the Diagnostic Readout Box (DRBII) scan tool or the Mopar Diagnostic System (MDS), or any other Chrysler-compatible diagnostic scan tool.
Here's a link to the codes.Tyler,join the A.Z.site at top right corner,it's free,then you can use there repair guides like me.
Oct 12, 2013 | Cars & Trucks
Where is the DATA LINK CONNECTOR (DLC) on kia sedona 2002
On 2002 Kia Truck Sedona 3.5L SFI DOHC 6cyl the OBD Diagnostic Link Connector is located under instrument panel...
Fig. Underhood sensor locations-Sedona 2002-2005
Sep 17, 2011 | 2002 Kia Sedona
Where is my diagnostics connection located on my 93 mazda mx6 4 cylinder?
For 1993 Mazda MX-6 2.0L MFI DOHC 4cyl the OBD Diagnostic Link Connector is located: Under hood, driver side, upper engine area, passenger side rear of air filter housing, mounted next to airflow meter connector.
Hope this helps (remember to rate this free answer)
Jun 04, 2011 | 1993 Mazda MX-6
Where is the diagnostic port located on my 2001 passat 5 sp. auto V6?
On the old Volkswagen Passat B5 (MY 1997-2001) the Data Link Connector (DLC) or diagnostic port is placed on the right side of the parking brake lever, under a small rectangle rubber cover. See pictures below:
On the new Volkswagen Passat B5 (after MY 2001) the Data Link Connector (DLC) or diagnostic port is placed on the panel above pedals. See pictures below:
Apr 06, 2011 | 2001 Volkswagen Passat
Looking for the diagnostic link connector Where is it?
OBD DIAGNOSTIC LINK CONNECTOR2000 Buick Park Avenue 3.8L SFI OHV 6cyl the OBD Diagnostic Link Connector is located: Front seating area, driver side, under dash, mounted under dash on driver side
2000 Buick Century 3.1L SFI OHV 6cyl the OBD Diagnostic Link Connector is located: Front seating area, driver side, under dash, mounted driver side of steering column
Just as reference; if you will send the specific year and model we will can confirm or posted additional details.
Hope this helps (remember to rate and comment this).
Nov 27, 2010 | Buick LeSabre Cars & Trucks
I am looking for port to use OBD II tool I can not seem to find it. Any idea where I can find it?
On GM and Fords it's on the lower left hand corner of the dashboard, underneath the dash. You may have to look closer to find it.
There may be a plastic cap on it concealing it from view.
It should be there:
Diagnostic Link Connector Fig. 1: The OBD-II compliant Data Link Connector (DLC) is located under the driver's side of the instrument panel 91144p39.jpg
Fig. 2: A Tech 1® , or equivalent scan tool must be used to retrieve codes from the 16-pin DLC connector 88254gc8.gif
These vehicles are equipped with a Data Link Connector (DLC) which is the 16-pin connector that you attach the scan tool to read and/or clear Diagnostic Trouble Codes (DTCs). The DLC is located under the driver's side of the instrument panel. prev.gif next.gif
Nov 12, 2010 | 1999 Chevrolet Malibu
How to change a throttle position sensor on a 94 ford f150 5.0 4x4
How to Replace a Throttle Position Sensor
(DIY & Save up to $135.75 ) - Time: 2.1 hours
Parts:
1. Throttle Position Sensor - $ 55.44
Tools:
1. Scan Tool
2. Screwdriver
3. Multimeter
Procedure:
1. Locate the OBD data link connector (DLC). Refer to your owner’s manual for the specific location.
  • Tip: The OBD-I data link connector is usually located in the engine compartment near the battery or the fuse box. The OBD-II connector (post 1995 cars) is usually located beneath the instument panel next to the steering column.
2. Turn your key to the“ON” position. Do not start the engine.
3. Plug your scan tool into the OBD data link connector. Turn on the scan tool and select the appropriate steps to read the diagnostic trouble code (DTC).
Scanner plugged into OBD-II data link connector.
  • Tip: The OBD-II diagnostic trouble code (DTC) is a 5 character alphanumeric code. The first digit is a letter that indicates the component group, the second digit is OBD mandated or manufacturer specfic, the third digit is a subgroup, and the fourth and fifth digits define the component and basic problem.
  • 4. Locate the throttle position sensor.
  • Throttle position sensor
  • 5. Disconnect the electrical connector from the throttle position sensor.
  • Electrical connector removed
6. Test the resistance of the throttle position sensor (TPS) with a digital multi-meter. If the resistance is out of specifications, the TPS must be replaced.
  • 7. Remove the throttle position sensor.
    Removing sensor mounting screws
    8. Install the new throttle position sensor. Tighten the mounting screws and attach the electrical connector.
  • 9. Erase the diagnostic trouble code (DTC) with the scan tool using the“delete” or“erase” command. Road test your vehicle to see if the check engine light returns.
    Check engine light
  • Tip: If the check engine light returns, repeat the diagnostic process for additional DTCs or take your vehicle to a certified repair shop.
Direct OE replacement
Hope helped with this. Good luck (remember rated this help).
Nov 05, 2009 | Ford F-150 Cars & Trucks
Where do i find the dlc plug
PLEASE DON'T FORGET TO RATE!!!! Data Link Connector OBD II Systems use a standardized test connector called the Data Link Connector (DLC). It is located beneath the instrument panel somewhere between the left end of the instrument panel and 12 inches (300 mm) past the vehicle centerline.
The DLC is located out of the sight of vehicle passengers, but should be easily viewable by a technician from a kneeling position outside the vehicle. The DLC is rectangular in design, capable of accommodating up to 16 terminals and has keying features to allow for easy connection. The DCL and Scan Tool connector have latching features that ensure the Scan Tool connector will remain mated when properly connected. Some common uses of the Scan Tool are:
  • To identify and clear any stored diagnostic trouble codes
  • To read the serial data stream information (e.g., PID data)
  • To perform Enhanced Diagnostic Tests (bi-directional Scan Tool)
Data Link Connector Graphic
Nov 01, 2009 | 2002 Oldsmobile Alero
Cannot find the code connector 1995 Ram 1500
Apr 03, 2009 | 1995 Dodge Ram
Mitsubishi Lancer 09 2009 Logo
80 people viewed this question
Top Mitsubishi Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Mitsubishi Car Audio and Video Expert? Answer questions, earn points and help others
