Question about Dryers
Iv had an idea for along time. About power comeing into our home,s. Id like to no if am right when useing 220 only there is no wast right. But when useing 110 volt there is some wast. Or when 110 v in oder to complet the circuit the return comeing frm lets say. 110 light blub go,s back to breaker box and is paired wht ground. Right? And wth 220 v that doesnt happen no wast right? Because 220v is 180 out of faze. Sorry about spelling. So do we wast power because of. 110V . And wouldnt we save power if we only used 220?
    Sergeant:
  • 479 Answers
All machine that run on 220v are more effeciant
Posted on Nov 26, 2013
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Bad 220?
What is your problem? Not drying? Not heating? Not running?
Posted on Mar 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: I need to use a 220 volt battery charger on a 110
Why not just get a meter pole with a 220 outlet installed near your parking space?
Posted on Mar 06, 2010
Jahn27
  • 1554 Answers
SOURCE: Hello, I've bought a Whirlpool dryer (model # :
Use a 110V to 110/220VAC transformer solely for the dryer. The transformer must have both 110 VAC and 220VAC output but you must be electrically knowledgeable to wire a 14-30R receptacle correctly and safely for the dryer. Perform the modification only if you are authorized to do so; otherwise, service of a licensed or authorized electrician is highly recommended. Refer to the wiring diagram of the recommended transformer.
Connect the terminals of the 4-wire receptacle (14-30R) to the transformer accordingly based on the diagram above. The only problem is how to determine the "neutral" terminal from the transformer output terminals.
The "neutral" terminal of the transformer can be found from the 110VAC output terminals without disassembling the transformer . Using a voltmeter, measure the voltage between each of the 110VAC output terminals and each of the 220VAC output terminals. The 110VAC output terminal in which voltage readings to each of the 220VAC output terminals are both 110VAC is the "neutral". The other 110VAC output terminal reads zero and 110VAC and this is NOT the "neutral".
Make sure the transformer power rating is appropriate for the dryer rating.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 10, 2011
  • 2006 Answers
SOURCE: how to get 220 from breaker box
You are measuring in the wrong place! If you have a double breaker in the circuit breaker box, measure the voltage at the dryer outlet. You should have 110, 110, 220 at the different terminals.
If that isn't the case, then replace the circuit breaker (assuming that you have the right input voltage into the house)
Posted on Jan 01, 2012
Frigidaire crown washer user manual
unless the model number tag says it can do 110/220 (on the tag) then you don't want to try this it will require a heavy expensive transformer ,wasting some of your power every time you use it.
for a manual , i could not find crown so youll need to look here.
http://www.frigidaire.com/Washers-Dryers/Washers/
May 14, 2014 | Frigidaire Washing Machines
Iv got a samsung sgh e250 wanna unlock it from tmobile to any sim card, but iv got an orange sim so even jus that'l do. iv manged to do the same with a nokia before but it seems much more troublesome...
Do not worry using the codes you can unlock your samsung mobile because its
safe for your mobile..........
Get the unlock code for your Samsung mobile from this site Theunlockarena.com , here it gives the unlock code along with easy methods for your mobile.........
Jan 23, 2012 | Cell Phones
Ipod touch will not restore just shows a usb lead to connect to itunes iv been thro all fault finding ie hold buttons together switch off etc !!! tried on another laptop and still wont work any ideas...
Press and hold the power button and the square home button at the same time for 30 seconds.
When you see the logo on the screen, let go of the buttons and wait for the iPod to start up.
Feb 15, 2011 | Apple iPod touch Second Gen (8 GB,...
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
Iv got a 2005 yz 250 stock whats the best way to hot it up
hot it up? you mean make it go faster ? wow it's a realy quick bike right out of the box if the bike seems to be lacking power easy check is the air filter ...pristeen like so clean you would eat off it? 2005 ...when was the last time the top end was done ? about every 30 hrs for a two stroke half of that if you are racing it by racing I mean getting on a motocross track and riding with other guys about your skill level till you have arm pump that makes you wish you had stayed home. if the above conditions have been met then a pipe is probably your most logical choice don't wast time and money on the engine making it high compression and needing race fuel 100++ octane is a total waste for all but the elite riders and it makes the bike unreliable and fussy "like a hot blonde pretty to look at but high maintence" Good Luck & Ride safe
Oct 12, 2009 | 2004 Yamaha YZ 250
Canon mp160 shows as 'off-line'
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
But some time when you get the chance do clean the waste tank out.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 24, 2009 | Canon PIXMA MP160 All-In-One Printer
Need some help
have you tried holding down the menu button and the center vutton at the same time?
Apr 16, 2009 | Apple iPod classic MP3 Player
L200 warrior turbo fault,drives ok for miles then suddenly no power engine light on, turn off then on all ok again
iv only st come on here and seen this post i know exactly what this problem is. it's the waste gate in the turbo gets full of carbon and then over boosts itself and put on the engine management light and when you turn the key on and off it resets it. so what you have to do id take the turbo off and clean out the waste gate which is on the exhaust side and that will get rid of all your problems and the better you clean it out the longer it will last.
Dec 14, 2008 | Mitsubishi Pickup Cars & Trucks
Overheated laptop for advent 7211
hi buy a can of air take cover off and give it a good blow, also try a laptop fan tray.
makesure there is nothing near it when its on and there is a good space from bottom
Dec 04, 2008 | Computers & Internet
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
