Question about Linksys Wireless-G WRT54G Router (DSLSWRT54G)
Router stopped working
I have the network set up for three computers aznd everything was fine. On sat morning the router stopped. I have disconnect the router to get this one computer to work. It no longer seems to send a signal to the wireless adapters. Any ideas?
  • Anonymous Feb 22, 2008
    The router stopped working.
  • 98 Answers
Try first to reset it to the factoty settings by pressing the brown button on the back of the unit, next to the Internet connection. You will have to reprogram the router with your PPPoE settings, if any, and your wireless security.
Posted on Oct 08, 2007
Worked fine up till yesterday now wireless wont work
The wireless cards in the computers need to be configured with the router's wireless settings so the computers can connect to the wireless router.
Resetting the wireless router back to the factory defaults will not let the computers connect to the wireless router without configuring the network card in the computers with the router's wireless settings.
I suggest you configure your wireless router with encryption settings to prevent unauthorized persons accessing your wireless network and Internet connection and your computers.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 01, 2012 | Computers & Internet
Have RV042 set up with Cox Cable and ATT DSL. System works fine as long as all client computers on network have a Static IP. I have DHCP enabled on the Router, when connecting a PC set for DHCP the router...
> everything is good
The connection between each computer and the router is the "good" part.
Thus, the router is routing packets "between" each of the computers (clients & servers) within your local area network.
However, your problem seems to be on the 'WAN' (Wide Area Network) side, namely between the router's WAN port and the DSL-modem, and/or between the DSL-modem and the telephone-jack on the wall, and/or the telephone-wires inside your walls, and/or the telephone-wires from the outside of your building to the nearest telephone company's CO (Central Office).
As a test, disconnect the router from the DSL-modem, and directly connect one computer, to see if the "then it will/not" behaviour still happens when the router is not active, i.e., "bypassed".
Then, contact your ISP, and get them to trouble-shoot while that one computer is connected.
Mar 09, 2011 | Linksys RV042 VPN Router
We plugged in the modem yesterday and ran the router and set up our wireless network. Everything was working fine on both our computers with our wireless network and neither one of us were plugged into the...
Your Wireless Router may have its name not broadcasting or hidden, check in the settings if it's hidden then manually connect your P.C.'s Laptops ,you won't find it using 'search for network'. Just right click on wireless icon near clock, select 'Open network and sharing center' and right click it. Now select 'Set up a new connection or network', Select 'Manually connect to a wireless network' and fill in the gaps. should work fingers crossed.
Aug 24, 2010 | D-Link DI 514 Wireless Router (DI-514)
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
DI 624 Was working ,disconected , reconnected work no more.
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
Click Here for more information about router and networks.
Jan 10, 2010 | D-Link Computers & Internet
My internet keeps dro, i have installed filters ,
There is one case where everything is fine but still connection drops too often.---
This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
If network connectivity itself is the problem then you can debug followingly.
Step-1:
If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
Step-2:
If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
Step-3:
Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
Nov 08, 2009 | D-Link Computers & Internet
Can't Connectda
Restore your router to factory settings, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses on the router.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
I have a Intel(R) PRO/Wireless 2200BG Network card on my Toshiba Satellite M50. One fine day, it was working fine on the network at home, and then suddenly got disconnected, and soon after stopped being...
I have the same card with Tecra A4. It was working fine with a D-Link 615 wireless router then for no reason it stop working I was able to detect my wirless network but no communication session started between my card and the router. I restrat the router and change the OS fro Linux to XP but still I have the same problem.
At the end I notice that in simple words my card cannot talk at all with the router. So I went to the router wirless settings and change the protocol from:
mixed 802.11 N, mixed 802.11 G, mixed 802.11 B
to only
802.11 G and 802.11B
Then it works fine onb both Linux and XP
Jun 12, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless router security
http://192.168.2.1 from a connected pc (use a cable you dont want to change settings over wireless and not be able to change it back) will start the router web interface, where you can read the help screens on how to, then set the router to one of several secure modes that it supports
The wizards are pretty good
Jul 08, 2008 | Belkin (F5D5231-4) Router
Wireless router
Make sure that the ehternet cable going from your modem is plugged into the slot on the router named internet.
Mar 30, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router (DSLSWRT54G) Logo
112 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
