The leds on the router are malfunctioning and my pc cant connect to it. tried many cables and tried the 30-30-30 hard reset but it wont work...
SOURCE: Diag led
s u can roll back teh firm ware while u doing this the device should be power on should not be distrubed>and while the firm ware downgrading u can see the power light is blinks>and once its study then reboot and check>if its not works change the device>rate me solved if its help full
SOURCE: wireless router not connecting
Be sure that your Modem plugs into the WAN port on the router.
1. Unplug your cable/dsl modem power
2. Unplug your Router power
3. Plug in your modem power ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
Press the reset
button on the back of the router for 45 seconds while it is powered on. This will do a factory reset. Wait for it to come up. Then unplug it. Wait 30 seconds and plug it back in. Let it come all the way up.
Plug a PC into one of the switch ports on the router.
Now do an ipconfig /release and ipconfig /refresh in the command prompt of your PC to get an IP address from your Router.
Now you should be able to ping 192.168.0.1 and you should be able to get into the the configuration utility by putting http://192.168.0.1 in a browser. The username should be blank and the password will most likely be admin (all lower case).
Be sure to lock down your wireless SSID
so neighbors and people passing by are unable to connect to your access
point and do bad things on your network.
SOURCE: WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
SOURCE: power led is blinking after I upgrade firmware
Something went wrong during the upgrade of your firmware. If you were upgrading the firmware from Linksys website you need to call their tech support and have them replace it for you. If you were trying to hack it with a 3rd party firmware you probably need to go buy another one and maybe consider using the firmware it comes with. You cannot restore the device because the flash killed the restore function. Your device is cooked. Put some BBQ sauce on it and serve it for dinner.
SOURCE: i cant get to 192.168.1.1 or get a signal on my
When ur connected with the router.. check the ip address in ur system.. if its is 192.168.1.1 then u can login by givin the correct user name and password..
