Question about Xylem - Flow Control Inc FloJet RV Waste Pump Kit
My flojet model 18555-000 motor is running backward
HOW DO I FIX MY FLOJET BW1000A BOTTLE WATER DISPENSER
bleed the air out of the pump suction line or prime the pump
Aug 31, 2016 | Flojet BW1000A Bottled Water Dispensing...
My flojet 4300-043 does not move much liquid even after prime, which I didn't think it needed.
FloJets don't need priming. If it isn't working properly, you just swap it out for a new one. We use them for soda syrups to a vending machine. They will pull syrup from a box through a 3/8" pipe with ease.
Jul 21, 2016 | Flojet 4300-043 4300-043a high flow quad...
Flojet 2.9 GPM 50 PSI Water Pump pulses-no steady stream.
Is it whirl-pooling because the water is too shallow? One thing you can do to prevent this is to lay a piece of plywood over it. It will float and keep it from whirlpooling and sucking air.
Jul 02, 2015 | Psi Garden
We have a Flojet pump 4300-143 which is leaking water out of the slots of the bearing cover (no10 on the parts list). Would you know what is causing this and which parts we would need?
Sounds like the seal has gone bad.most hardware stores carry seal kits and some even install them for a fee.Replace the seal and that should solve your problem.
Hope this helps.
Bob
Mar 27, 2015 | Flojet Pump: 4300-143 12 Volt, 4.9 Gpm,...
My flojet 4305 drinking water pump on my boat does not pump as efficiently as in the past - how can I troubleshoot it?
when you close all cocks the pump must stop running after a short while, if not clean inside of pump (diaphragm and valves) and try again. If pump is continuously running try to pump 5 liter water of 70 deg. C if problem is still a continuously runnnig pump there is a electronical problem which can not be repaired or replaced in this modelrange
Nov 09, 2010 | Flojet Sensor Vsd Water System Pump
My flojet pump runs but it pumps no water . It is a 25 gallon sprayer
Sounds to me like it just needs priming (or in other words) the air bled out of it.
Using the force of gravity, force water to run STRAIGHT DOWN from the 25 gal tank, through the gate valve & into the running pump.
While doing this, close the bypass valve slowly until it's about 3/4 of the way shut.
You should begin to hear the sound of the pump begin to deepen as the air escapes.
If you don't, then there may be an air leak somewhere along the hose line, typically at the filter, causing it not to prime.
Correct the air leak, then you'll probably have better luck.
I recommend not running an electric pump like a Flojet for very long when it's not primed. Doing this may overheat it & shorten its lifespan considerably.
May 19, 2010 | Flojet Ag Sprayer Pump 2.1 Gpm 12 Volt...
Xylem - Flow Control Inc FloJet RV Waste Pump Kit Logo
29 people viewed this question
Top Xylem - Flow Control Inc Plumbing Experts
Donni Steen
Tom Chichester
Are you a Xylem - Flow Control Inc Plumbing Expert? Answer questions, earn points and help others
