Question about Canon FC120 Black and White Copier
On my fc120 when I want it to print multiples of paper f it keeps going back to p
Why does the paper twist going into machine
Some images or more detail description would be great, however most common issue is piece of paper/other small objects(I have read about small pencil found in the printer some time ago) stuck in the path of the paper from previous jams. Also check if the paper has correct size.
Nov 07, 2015 | Canon FC120 Black and White Copier
Error, paper out, when paper is loaded.
check there is the sensor cable is broken or the sensor is faulty.
Oct 12, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
Printing multiple page pdf on kodak esp c310 AiO
I had exactly the same problem as you! Whenever I printed anything of more than 1 page the paper jammed. I now know why... When you go to File>Print in Adobe reader, the print window displays a load of options. Simply uncheck the 'Print on both sides of paper' box. This worked for me! Hope it works for you!
Eoghan12
Jan 31, 2012 | Office Equipment & Supplies
Message comes on: Clearing paper path and the printer keeps printing multiple copies
Hi there.
The printer driver is corrupted that keeps printing in multiple page. I suggest, you add new printer with the same name and set it as default printer. When you print the test page and it prints it means your problem is solve. Then delete the printer icon.
I am sure it will helps you a lot.
Feb 08, 2011 | HP LaserJet 2420 Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
Multiple page print job doesn't finish when paper runs out
This printer should continue to work one paper is added. If not hitting the continue button (Top silver button with an exclamation mark on it) should allow it to resume.
After that can you tell me what the blink sequence is being displayed on the panel?
Jun 17, 2009 | Lexmark E232 Laser Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
Too Much Paper
2 possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Apr 02, 2008 | HP Photosmart 7450 InkJet Printer
Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
Canon FC120 Black and White Copier Logo
24 people viewed this question
old marine
old marine
