Question about Keurig B60 Coffee Maker
Kureig heats but won't brew - Keurig B60 Coffee Maker
    Problem Solver:
  • 8 Answers
The exit needle could be clogged located( inside bottom of the holder assembly). Remove K-cup assembly and detach funnel. Insert a paper clip or simiilar tool into the exit needle to loosen the clog and push it out. REMEMBER, the needles are very sharp, proceed with caution!!
You may also need to Descale your Keurig...I do this every other month due to high mineral content in my potable water. Change out resevoir filter and clear exit needles as part of Descaling. Disable "auto shut off" feature, remove reservoir filter and do not use a kcup prior to proceeding. Place 48ounces of white vinegar into reservoir, press brew, discarding each mug of water down kitchen drain and repeat until "Add Water". Let brewer stand for four hours in "On" . Rinse after 4 hours by filling water reservoir with fresh water and press brew until ADD WATER is indicated.
I run two full fresh water cycles before actually using the Keurig for beverages I will consume.
Hope this helps
Posted on Nov 17, 2013
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
Frigidaire 12 cup coffeemaker won't brew
Like the one i own, the heating /warming plate is bad and needs replacement. I have not been able to find one.
Nov 14, 2012 | Frigidaire Professional 12-Cup Coffeemaker...
The reset button popped and now won't reset.
Circuitboard problem. Needs replacement.
Nov 02, 2012 | Keurig B200 Brewing System
Krups KM7000 won't make a full pot.
I have one. there is a setting on how many cup you want 4,6,8,10, or 12 cups
Oct 18, 2012 | Krups KM7000 10 cup Grind and Brew coffee...
Bloomfield coffee maker won't brew hot water
Do you mean the machine will not heat up?
Oct 18, 2012 | Bloomfield 8572 Coffee Maker
Kureig elite not powering on
Check power outlet or circuit breakers.
Sep 18, 2012 | Keurig Elite B40 Coffee Maker
Kureig say prime will not make a cup of coffee
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 25, 2011 | Keurig B70 Coffee Maker
It won't brew when it says its brewing. Why won't it brew my coffee? Just seems to be really slow and I have only had this coffee maker about a year.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 18, 2011 | Keurig Platinum B70 Coffee Maker
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Keurig B60 Coffee Maker Logo
134 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
