Question about Bosch AXT 22 D Electric Drum Garden Shredder
Garden shredder axt 22d jammed
Shredder is jammed. Tried clearing. Not worked.
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Bosch AXT 2200 HP shredder motor turns the wrong way
Try flipping the plug on the wall plug it in c which way the unplug rotate an plug it in again I no when working with. Motor proper polarity determined direction
May 21, 2014 | Bosch AXT 22 D Electric Drum Garden...
My chipper shredder is jammed
I hate to say it but sometimes it is harder to fix than normal. I had to use a small chisel once to chip away at scrap wood until I could get it to move. I don't know the model but it might be possible to use a small hand saw to cut at the knot. it is very troublesome to work on that problem
Mar 16, 2014 | Bosch AXT 22 D Electric Drum Garden...
My shredder won't power on. It is not overheated.
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Aug 11, 2013 | Staples Cross-Cut Shredders; 10 Sheet
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My son put a 25 page document in this shredder and bound her up better than any shredder jam I've EVER seen. What's the best way to clear this mess when the shredder can't overpower the jam? I'll pull...
    There are various ways to clear the mess if you have patience and the time to work the jam. 1. Unplug the shredder and use a flat-head screw driver to dig as much out as you can, then plug it back in and flip the switch from forward to reverse a few times and then keep repeating the process until jam is cleared. 2. Use tweezers to remove paper from critical connection teeth and the try it again.
    Nov 16, 2010 | Fellowes Manufacturing Powershred SB-97CS...
    My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
    Instructions
    Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
    Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
    Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
    Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
    Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
    Good Luck!
    Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
    Shredder stopped suddenly and won't work
    If you are unable to clear the jam, turn off and unplug the shredder;
    remove shredder head from the wastebasket and carefully remove any paper extending
    below the cutting cylinders; empty the wastebasket; reassemble the shredder and repeat
    if still do not run follow the next steps:
    1. Make sure shredder is plugged in and
    switch is in automatic [I] position.
    2.Wait 15 minutes for shredder to cool
    down before trying again.
    3.make sure that the shredder head is in the correct position, if is not it will not run
    please rate the post for i to know do this is helpful if not i will know by your rate that i should post some more information
    Jan 11, 2010 | Fellowes P70CM Shredder
    Broken Bosch AXT 2000 HP Shredder
    Chances are there is a branch wedged in the blade assembly. Are you able to pull the starter cord? if not, you'll have to remove the housing that covers the blades and remove the blockage.
    When you expose the blade use a bar to reverse the blade and release the tension, If it was blocked it should start up right away.
    May 04, 2009 | Heavy Machinery
    Bosch AXT 22 D Electric Drum Garden Shredder Logo
    56 people viewed this question
    Top Bosch Garden Experts
    roeb
    cwradio73
    Are you a Bosch Garden Expert? Answer questions, earn points and help others
