Question about Siemens DX800A Gigaset DX800A Multiline Desktop Phone for VoIP and ISDN
I don't have a telephone line alhtough the adsl works fine. Telecom says that the problem is on the phone(A130 GIGASET)
2 Suggested Answers
  • 82 Answers
SOURCE: Where can I download hungarian
Azt hiszem, hogy magyar nyelven nem letezik. Nezd oda: http://goo.gl/iACdB. There are different versions, it seems, and hopefully you can find your answer.
Posted on Jun 17, 2011
Will a Gigaset A220 A cordless phone work on a government spectrum phone line
If a telephone line is presented as POTS (Plain Old Telephone System) or a standard telephone will plug into the line, then the Gigaset A220 will work on it.
Feb 09, 2015 | Lands Phones
Incoming voice is very low.battery is in fully charged condition.Volume is also set at max. WE are putting the call under speaker phone and continuing the call.
If you have ADSL line also connected to the same phone then it is because of that...
To solve the problem simply buy one vioce filter and install it in your phone line it should cost you around 2$.
Aug 09, 2013 | Siemens GIGASET-A49H GIGASET-A49H
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
Seimens Gigaset AL285 BSNL caller ID not working
The source of my caller ID not displaying was a faulty ADSL filter.
For some reason my ADSL filter blocked the caller id information - but worked fine otherwise.
When I changed the filter the caller ID worked fine again.
Jun 05, 2012 | Siemens Lands Phones
When my home phone rings my internet disconnects
You need to make sure that you have an ADSL line filter connected before any home telephone or DECT base station (eg. a filter is required on the line between your physical telephone device and phone socket). This can also be achieved via a central ADSL phone line splitter.
---------- ADSL Filter -----> Telephone Handset 1 or DECT base station
<--- main telephone line --/
\-----------------------------------> ADSL Modem/Router ---> Computer
\----------ADSL Filter -----> Telephone Handset 2
Hope it helps: let me know how you go.
Dec 13, 2010 | Cell Phones
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Hipath 3550 CLI on ADSL Line
Try #86 on each handset to enable CLI and *86 to suppress CLI.
From V3 to V7 is big. Motherboard upgrade.
Sep 07, 2009 | Siemens HiPath (L28155H5100A402) IP...
Adsl connection
have the phone company check the line for "ring and tip" make sure they are the same as before, I suspect that the wire is reversed. the telephone don't care how the wire is run.
Nov 06, 2008 | Dynalink (V1456VQH) Modem
Siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
Error 106
the ipaddress of the router may not be 192.168.1.1 it should say somewhere on the router or the documentation
if you are suing DHCP to allocate the IP address, and the router is set as a DHCP server you should be able to see the ipaddress using whatever tools Apple give on settign up networks.
I think there is possibly something wrong with your telephone line setup check that no phone is connected unless its through a adsl filter, or you have an adsl socket on the master socket in the house. The fact that you are not getting the online light to light up suggests to me that the router isn't talking ADSL network. consider removing ALL phones temporarily and see if that helps...
you should be able to PING an IP Address, again I don't know how youd do that on a MAC, hate 'em personally.
usually all you need to know are the IP address of the gateway (the router). set the DNS to the same IP address, unless Tiscali advise otherwise
the ADSL filters should only remove the hissing noise on the telephone line, so after plugging in the filter the phone should work as normal..
Apr 29, 2008 | SMC EZ Connect Wireless Networking Starter...
Siemens DX800A Gigaset DX800A Multiline Desktop Phone for VoIP and ISDN Logo
105 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
