Question about Oreck XL Ultra Bagged Upright Vacuum
How to remove upper handle tube - Oreck XL Ultra Bagged Upright Vacuum
My hoover steamvac trigger won't spray
Remover the upper handle assembly and check the linkage (inside the upper handle) where it connects to the button/trigger assembly in the handle grip. This may have detached or the trigger may be loose from its mount in the handle. Reattach or replace the broken part.
Sep 03, 2014 | Hoover V1 SteamVac SpinScrub Vacuum
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
Cannot remove the lid of main housing
I have a model Bissell Proheat Platinum II Model 1699 that was not spraying. It probably is similar to yours.
As stated in other posts, the heater is located within the lower half of the handle where the POWER HEATER switches are. There are quite a few screws. It's easy to miss the one at the very top of the handle. First remove the accessory caddy and then remove one half of the upper handle. The other half of the upper handle lifts straight up allowing you to split the lower part of the handle into a "V". It pivots at the bottom around the wheels. It took me a while to figure out that I needed to LIFT that part of the handle straight up.
Once you split the lower half, you will see the heater (aluminum box). There are two ports on the heater where the two lines connect to the heater (in and out). Use pliers to loosen the spring clip where the tubing connects to the heater to remove each line. My lines were okay. One of the ports on my heater was plugged. I used a 1/16" drill bit and hand reamed out the crud. You don't need to use a drill -- use your hand - it's safer. After you have cleaned out the ports and your tubing (if needed), suggest you try it out after reconnecting the lines to the heater but before you put the handle back together. You may find that the lines or port needs more cleaning. Make sure you have water in both the water and cleaning solution vessels. As you know, no water will spray if EITHER one is dry. Turn it on and then press the little spring that's still in the handle. Hopefully you will get a water spray.
When you put the handle back together, be careful that you don't crimp the tubing. Tuck them back in the notches in the handle.
Hope this helps . Good luck.
Apr 02, 2014 | Bissell 1698 PowerSteamer ProHeat Upright...
Xl2600hhvacuum won't stand alone anymore, what is broken, is it a spring or some kind of catch missing
The detent that is mounted to the inside of the base cover is not working either because the screw holding has broken off or it is worn out. You could also have a worn out fan housing since that is what the detent catches to make it stand up. If the screw is broken off the only way to repair it is to replace the housing. Hope this helps.
Jul 15, 2013 | Oreck XL2600HH Upright Vacuum Cleaner...
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 | Vacuums
It won't spray water!!
I have a model Bissell Proheat Platinum II Model 1699 that was not spraying. It looks to be very similar to your model. From reading other posts, this is what I did:
Frst make sure it isn't the pump. Try spraying with your accessory. The accessory does not use the heater. If you get spray with your accessory, your pump is okay. If you don't get spray, check the belt to the pump. If it isn't the belt, you may need a new pump.
Luckily, I got spray with my accessory, so now you need to check your tubing from and to your heater. As stated in other posts, the heater is located within the lower half of the handle where the POWER HEATER switches are. There are quite a few screws. It's easy to miss the one at the very top of the handle. First remove the accessory caddy and then remove one half of the upper handle. The other half of the upper handle lifts straight up allowing you to split the lower part fo the handle into a "V". It pivots at the bottom around the wheels. It took me a while to figure out that I needed to LIFT that part of the handle straight up.
Once you split the lower half, you will see the heater (aluminum box). There are two ports on the heater where the two lines connect to the heater (in and out). Use pliers to loosen the spring clip where the tubing connects to the heater to remove each line. My lines were okay. One of the ports on my heater was plugged. I used a 1/16" drill bit and hand reamed out the crud. You don't need to use a drill -- use your hand - it's safer. After you cleaned out the ports and your tubing (if needed), suggest you try it out after reconnecting the lines to the heater but before you put the handle back together. You may find that the lines or port needs more cleaning. Make sure you have water in both the water and cleaning solution vessels. As you know, no water will spray if EITHER one is dry. Turn it on and then press the little spring that's still in the handle. Hopefully you will get a water spray.
Feb 20, 2011 | Bissell 1698 PowerSteamer ProHeat Upright...
When running the 2100 Electrolux vacuum, it is stopping and starting when pulling or pushing the floor attachment. Seems like the connection at the top of the handle is a little loose or the electric tabs...
Depending on the age of your 2100, you will need to replace, the wand cord, the handle wiring and perhaps theh upper wand inner tube and handle as well.
If you examine your cord contacts they will be blackened from slippage, so will the female socket they plug into. On and aging 2100 the 1/2 inch groove at the front of the chrome handle tube begins to wear and the metal inner tube clip under the thumb button of the wand develops play back and forth. The wand comes apart into 4 pieces, plastic sheath, upper and lower tubes and cord assy.
If the hose handle groove is worn enough to allow in and out play, you will need to replace the handle, it's wiring, and at least the clip button on the upper wand as well as the wand cord.
You will find these wand parts at a pro vacuum shop but if your hose is original you will need to go to an AERUS Electrolux repair center for parts.
Post back with your results.
Nov 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Forward/back cable broke
The cable is user replaceable, but you will need to contact Hoover, or a parts center, to purchase the cable. You will remove the Upper Handle by removing the black screws at the base of the upper handle fit to lower handle (on back).
You will also have to remove the hood to loosen the one screw that holds the cable to the powerdrive gearbox.
Oct 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Remove hose from handle on old electrolux canister
BE careful here. Do not fish a coat hanger in the handle.
The original hose has a set of detachable handle componnets.There are two metal screws in the underside of the hand grip.Do Not pry. Once removed go to the suction dial area underside of the grip. Observe the plastic fingers near the dial. These must be reset in their " track " when reassembling the handle.
Gently insert a small flat screwdriver between the rubber wiring contacts and the plastic tongue wraps around the socket. this tongue which extends from the hose handle adjacent to the metal tube. Work you way back to the hose area carefully separating the "hand grip cover" from the hose handle itself.
Once apart remove the obstruction. Carefully clean the two brass rings looking for any pitting. If pitted, gently polish by rotating fine wet/dry sandpaper around the rings, then lube with vaseline.
The matching contact fingers on the handgrip cover should be cleaned as well and gently tensioned to put a bit more presusre on the contact rings.
Slide the handle ONLY onto the hose. Once in place the contact rings will be visible. Now you can work the handgrip cover back into place starting with the two tabs at the hose end below the contact rings. To seat the small fingers at the control valve gently click into place before reinstalling upper handle screws.
Jun 15, 2009 | Electrolux Central Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
16 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
