Question about Ricoh Aficio SPC312DN Laser Printer
Reset waste toner correctly empty - Ricoh Aficio SPC312DN Laser Printer
  • 48 Answers
rasadam
  • 5 Answers
SOURCE: Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Posted on Jan 23, 2007
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
jaylex
  • 417 Answers
SOURCE: We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Posted on Jan 28, 2008
SOURCE: can you resue a waste toner bottle
Change the waste toner bottle. :-)
Posted on May 14, 2009
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Posted on May 27, 2010
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Reset Waste Toner in a Brother
  1. Remove the full waste toner box per manual.
  2. Wear breathing protection as there will be toner dust in the air.
  3. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder.
  4. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth.
  5. Place the box flat on the bench and inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out.
  6. Replace the cover and 6 screws and replace the waste toner box in the printer.
  7. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jan 24, 2014 | Brother WT300CL Waste Toner Box
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
WASTE TONER CONTAINER
The Counter for the Waste Toner has to be reset. You go into service mode by selecting Additional Function, then depress the 2 & 8 at the same time then the Additional function key once again. You should see a screen that says copier, feeder, etc. Touch " Copier " and then you should see a new menu across the top of the screen. Far right is " Counter ". Select it and then go to " MISC ", you should see Web, Waste toner, etc. Select Waste toner and select the " C ( clear ) " key and the counter should reset to all zero's.. Select the reset key a couple of times to get out of service mode. You may want to see what's all in service mode to get an idea of what's there. When replaceing time change items most likely there will be a counter to reset in the same way. Good Luck.
Sep 24, 2008 | Canon imageRUNNER 5570 Copier
just clean out the transfer belt
Sep 20, 2008 | Office Equipment & Supplies
IR7095 e000019-0000 error
This is the waste toner container and its location.
Jun 24, 2008 | Canon Office Equipment & Supplies
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh Aficio SPC312DN Laser Printer Logo
121 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
