Milky oil on dipstick of 2002 Pontiac Montiac
    Top Expert:
  • Computers & ... Master
  • 26,637 Answers
Water in oil caused by head gasket or it has been stored for a few years.
Posted on Nov 17, 2013
Length of oil dipstick for a 2002 dodge ram 1500 4.7 v6 cause when I try to check oil with the one that is there the oil is way up past full mark
The 4.7L is a V8. Did you just get the vehicle? Has the oil been at the normal level until now? Check the color of the oil - if it looks milky, you may be getting coolant in your crankcase making it overfull. If the oil looks normal (clear and clean), find someone else with the 4.7L engine and compare dipsticks.
Jan 27, 2016 | Dodge Cars & Trucks
I HAVE THIS 2005 CHRYSLER PACIFIC HAD TRANSMISSION FLUSH AFTER DRIVING IT ..IT OVERHEAT NOW WHITE MILKY SUBSTANCE IN COOLANT RESAVOIR WHY ??
You need to check the oil and see if the dipstick shows overfill on oil or if you see the white milky substance on the dipstick you may have a blown intake gasket or head gaskets. I would think it sounds like a blown head gasket. Hope this helps.
If you are adding water to the system you have a problem somewhere you might want to run a compression check on the cylinders to see if you have a intake gasket leak or a head leak. How hot did the car get because you might have cracked a head. If you don't see the water in the oil it may be exhausting out the tail pipe.
Sep 14, 2015 | Chrysler Cars & Trucks
I have a 2005 Chrysler Pacifica. It is milky brownish color in my anti freeze. My car is not over heating and oil dipstick is okay it does not have the milky stuff present mechanic says he do not think its...
milky color is most likely oil from somewhere. I would give is a good cooling flush and see how long it takes to come back
else need more information
Feb 16, 2018 | 2005 Chrysler Pacifica
Milky oil dipstick, white exhaust smoke, coolant in spark plugs
*White milky oil on dipstick = coolant in oil.
*Coolant on sparkplugs = cracked head or blown head gasket
*White smoke = burning excessive oil in the cylinders, which can be caused by a number of things including valve seals, cracked head or blown head gasket.
***All three of these symptoms together, however, means its the head or head gasket. Both are costly but better the head gasket than the entire head.
Jan 18, 2012 | 2002 Buick LeSabre
Noticed it was overheating, let it cool, removed radiator cap, saw this brownish substance all over the inside of cap and in radiator. What is it and what should I do?
the brownish is oil/the head gasket busted threw letting in oil to the water pull the dipstick and see if there is any moisture or milky looking substance if so look for another motor or have the heads magnafluxed for cracks
Mar 24, 2011 | 2004 Pontiac Grand Prix
2001 pt cruiser over heating wired fan direct fan works but car still over heats replaced thermostat temp. sensor fuses etc...
Sounds like the engine head gasket needs to be replaced.The gasket has deteriated from the engine cylinder and coolant passage and overheating the coolant. Sometimes you will see coolant mixed with engine oil, or milky solution on the oil dipstick
Feb 21, 2011 | 2002 Chrysler PT Cruiser
Milky appearance on the oil cap
Generally that means water in the oil. Is the oil on the dipstick the same color? If so, it could potentially be something very bad, such as a leaking head gasket or coolant passage that is allowing antifreeze to leak into the engine when under pressure. If the milky appearance is just on the refill cap and the oil on the dipstick looks normal, then you could just have a small amount of water from condensation. That can happen if the vehicle sits a long time without being used.
Nov 28, 2010 | 2002 Jeep Liberty
I have a 2002 Jeep Liberty with a 6 cyl. and the coolant continues to get low but I cannot find a leak anywhere.
It may be your head gasket is bad. This would allow coolant into the combustion chamber and/or oil pan. A couple ways to determine this: check the oil level, if it is too high, you may be getting coolant in it, also, the oil on the dipstick or when drained has a 'milky' white-ish look to it. Check the exhaust after the car warms up, do you see white exhaust smoke? This also indicates the head gasket is bad.
Jan 02, 2010 | 2002 Jeep Liberty
Coolant boiled over in resivare.
This sounds like a major problem. If you over heated the motor and the oil is milky you probably blew a head gasket or warped the heads.
Mar 16, 2009 | 2002 Dodge Stratus
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
