The pilot does not stay on
Renzor garage heater
Change the thermocouple
Posted on Nov 17, 2013
2 Suggested Answers
  • 77 Answers
SOURCE: i have a comfort glow
you have a fuel flow problem somewhere. you need someone with a flowmeter and an ounce pressure gauge to check all your regulators and control valve.
Posted on Jan 22, 2010
I have a williams wall heater in the garage model #3003612 the pilot wont stay lit what shall i do?
shut off gas use compressed air blow into and around over any tube. retry the pilot
Nov 01, 2015 | Williams Heating & Cooling
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
I have a mr heater 75 btu garage heater it lites and stays on for 5 seconds and gos out relites gos out than it locks out
Try cleaning the flame sencor , check pilot is clean , check the tubes on the pressure switch are not split and are tight , there are high and low limit switches on there try jumping them out one at a time , see if any of this helps .
Aug 22, 2011 | Mr. Heater Natural Gas Garage Heater -...
I have a 25,000BTU Enerco IR garage heater that is about 12 years old pilot light does not stay completely lite it makes noise and smells like gas
When was the last time you cleaned and serviced the heater? From what you described, it sounds like the pilot is clogged, as well as the burner. That's why it's making noise and smells like gas. Not all the gas is being consumed.
Mar 29, 2011 | Mr. Heater MH40LP / MH40NG Infra-Red
Pilot wont stay on furnance in the garage. About 20 years old
clean pilot and change thermocouple see if this works
Jan 07, 2011 | Dayton Gas Furnace Heater
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
